Voltage and ampage q
CaNsA
PostPosted: 12:02 - 30 May 2010    Post subject: Voltage and ampage q Reply with quote
laptop requires 19v 3.42A
the only charger i have for it pushes
20v 3.25A
it will be okay until i get the right one this week yeah?
T1z3R
PostPosted: 12:27 - 30 May 2010    Post subject: Reply with quote
IMO its under powered so will overheat badly.
i wouldnt.
duck my sick!
Frost
PostPosted: 13:23 - 30 May 2010    Post subject: Reply with quote
Lower ampage should be okay, it will just charge at at slower rate. Voltage being over is a problem.
carvell
Scuttler
PostPosted: 13:31 - 30 May 2010    Post subject: Reply with quote
No, not necessarily. If the laptop tries to pull more current then not only is the power brick going to get hot and probably break, the voltage into the laptop will end up decreasing too. It's not going to do it any good.
Having said that, it's highly unlikely that the laptop will end up pulling the full 3.42A anyway.
The 1 volt over is technically a problem, but it will probably be fine being a volt over.
It'll probably all be fine. But there's a chance you'll break something.
Yamaha TDM 850
Frost
PostPosted: 15:10 - 30 May 2010    Post subject: Reply with quote
Knackering a power supply is an inconvenience. Knackering a laptop is alot worse. Chances are it's 19v for a reason.
The last post was made 16 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 42.31 Kb
