Bike Batteries...
m0l0t0v
PostPosted: 17:09 - 31 May 2010    Post subject: Bike Batteries... Reply with quote
Well, the GT550 battery is still alive. Just the bolt broke off as well Rolling Eyes. I can still connect it but only if I physically hold it down. Tried using insulating tape so hold it down and have it connected and while ti worked, every time I hit he starter button it would cut out. Not even time to turn over. So no idea how to bodge it...
But are bike batteries transferable? I've got my Hornet battery which is still alive but it's a sealed type while the GT (Kawasaki) is an unsealed type you fill with acid...
Much danger in using the Hornet battery? Even say for a short time? As I can get a new one bu not till Wednesday and the earlier I can get on the bike the better.
'92 Kawa GT 550, '98 Hornet 600.
Praying
Alexio
PostPosted: 17:24 - 31 May 2010    Post subject: Reply with quote
Is there really not a way of you holding two bits of metal together?
I know that last week every time I wanted to start my bike I had to physically hold the wire on to the batter so that the starter would work Laughing
Anyway, there must be something stronger than insulation tape. What about cable ties? Razz
m0l0t0v
PostPosted: 17:34 - 31 May 2010    Post subject: Reply with quote
Can't use cable ties. The connectors is quite short so I couldn't only use insulating tape. It held it... just didn't seem to work!
And I can start it up but it just dies...
Alexio
PostPosted: 17:46 - 31 May 2010    Post subject: Reply with quote
It dies because the connection isn't very strong you think? Clearly you require a soldering iron Wink
m0l0t0v
PostPosted: 17:47 - 31 May 2010    Post subject: Reply with quote
I have a soldering iron and solder... come to think of it...
BRB Mr. Green
WetSparks
PostPosted: 17:49 - 31 May 2010    Post subject: Reply with quote
Battery type, sealed or not, wont make a difference. The only problem is that is you fit an acid battery where you had a sealed type, you will have to provide a vent pipe for the battery. The only real stumbling block is going to be physical size and wiring polarity orientation.
On the other battery, can you not solder a lump of wire to the broken post and then connect to that?
m0l0t0v
PostPosted: 17:52 - 31 May 2010    Post subject: Reply with quote
Awesome.
Will try soldering the battery. If that doesn't work I'll use the Hornet battery.
Thankfully it's going from acid to sealed so shouldn't be a problem. Ta guys Thumbs Up
m0l0t0v
PostPosted: 18:30 - 31 May 2010    Post subject: Reply with quote
Done. I've soldered it. Mr. Green
New battery is on the way anyways, thanks to mother dear.
Alexio
PostPosted: 18:45 - 31 May 2010    Post subject: Reply with quote
And it's all working?! Haha, wow I think I deserve karma or something Laughing
m0l0t0v
PostPosted: 18:56 - 31 May 2010    Post subject: Reply with quote
Don't make me get the BCF rule book out Razz Tut Tut
Alexio
PostPosted: 19:00 - 31 May 2010    Post subject: Reply with quote
Yes sir Sad I only said so because I'm still surprised a non-serious suggestion was taken seriously in the workshop and it has solved a problem Shocked
Ohhh, look, a penny! Penny Coin
m0l0t0v
PostPosted: 19:06 - 31 May 2010    Post subject: Reply with quote
No worries. Another guy did mention it too Razz
I got lots of pennies (think about 20 quid in them!)
Alexio
PostPosted: 20:03 - 31 May 2010    Post subject: Reply with quote
I've got at least £30 worth of coppers. It's fantastic.
jimspeed
PostPosted: 14:40 - 01 Jun 2010    Post subject: Reply with quote
i just drilled a 2mm hole in the remains of my terminal and fitted a self tapping screw, the terminals go quite a way inside the case so as long as you are careful you should be ok..
did mine ages ago and its still ok
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
m0l0t0v
PostPosted: 15:00 - 01 Jun 2010    Post subject: Reply with quote
Meh. The soldering has held on with good and bad wheelies and harsh baking so I think it'll do Smile
The last post was made 16 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.71 - MySQL Queries: 13 - Page Size: 97.55 Kb
