cb125 superdream help
Garth84x
PostPosted: 19:12 - 01 Jun 2010    Post subject: cb125 superdream help Reply with quote
hi all,
Im having a spot of bother with my 125 superdream..
the engine has had a rebuild, and all seems well except when i've put it all back together the gear selector shaft that runs through the engine is solid and wont select the gears, and i do mean solid. Even after i stripped it down again and removed the gearbox it's still solid
Any ideas what i've done?
Garry
cb1rocket
PostPosted: 19:17 - 01 Jun 2010    Post subject: Reply with quote
is the shaft actually stuck in the case?
I'm not sure how you can take the gearbox apart if the shaft is stuck in?
Garth84x
PostPosted: 19:20 - 01 Jun 2010    Post subject: Reply with quote
All the gears and the selector drum come out as on lump, then you can seperate them once removed, the selector moves in and out of the casing but is really hard to turn.
cb1rocket
PostPosted: 20:56 - 01 Jun 2010    Post subject: Reply with quote
I would check the drum and slector forks are refitted correctly? It might be assembled wrong, take apart and start again would be my best bet.
Are you following a haynes manual or something?
Garth84x
PostPosted: 21:17 - 01 Jun 2010    Post subject: Reply with quote
yeah... haynes manual, well try too
cb1rocket
PostPosted: 23:27 - 01 Jun 2010    Post subject: Reply with quote
yeah best bet would be to take apart and start a fresh, you might see notches on the cogs and selector, drum etc that would otherwise line up. Its quite easy to get carry away from the haynes manual and not realise somehwhere we have gone wrong.
My money is still on the drum and selector forks or the selector return mechasim being jammed, or installed wrongly.
Keep at it, your get there in the end.
Was it ok before the rebuild?
Garth84x
PostPosted: 00:04 - 02 Jun 2010    Post subject: Reply with quote
Yeah was fine....i've taken it apart 2-3 times and tried again...it's a pain as you have to split the casing each time...ill try again weekend..
garry
The last post was made 16 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 49.78 Kb
