Changing chain + sprocket on rr5 blade
Chinaboy
PostPosted: 21:11 - 02 Jun 2010    Post subject: Changing chain + sprocket on rr5 blade Reply with quote
Just after a bit of advice please guys.
The front sprocket on my RR5 blade is under a cover, but over the cover is a casing for something else which looks like it needs to come off also to get to the sprocket. Can anyone tell me what this is and can it be removed without loosing any fluids.
Thanks in advance
Steve
Jesta_ZX6R
PostPosted: 01:37 - 03 Jun 2010    Post subject: Reply with quote
No idea, but a photo would help.
DrDonnyBrago
PostPosted: 09:49 - 03 Jun 2010    Post subject: Reply with quote
Some bikes have the speedo sensor in the sprocket cover, although I am 95% certain yours is on the crankcase...
As above photo would help Thumbs Up .
Chinaboy
PostPosted: 22:02 - 03 Jun 2010    Post subject: Reply with quote
ok, I will try to get a pic up for tomorrow. I did however download the user manual from the sticky thread, but in the removal photo it still does not show what it is Sad
Thanks for the trouble guys Thumbs Up
DrDonnyBrago
PostPosted: 23:19 - 03 Jun 2010    Post subject: Reply with quote
Does the manual say you need to do anything special to get to the sprocket?
If not then just i'd pull it off and see what it is Thumbs Up .
SamJL
PostPosted: 00:19 - 04 Jun 2010    Post subject: Reply with quote
Try this website, loads of helpful information:
https://www.1000rr.net
2009 CBR1000RR
2004 KTM 200SX
2004 KTM 65SX Very Happy
Chinaboy
PostPosted: 17:20 - 05 Jun 2010    Post subject: Reply with quote
Sorted it guys.
It is the clutch push-rod housing. Not a problem to remove, it comes off by just undoing the bolts. I found though that to remove the cover, you need to split the old chain and remove it completely from the front sprocket before you can get the cover off.
Thank you for your comments and help
Vincent, I am in North Dorset.
Steve Smile
The last post was made 16 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 55.06 Kb
