Engine Oil
ashwell-09
PostPosted: 11:40 - 03 Jun 2010    Post subject: Engine Oil Reply with quote
Just checking if an oil like:
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_263777_langId_-1_categoryId_165507#dtab
Will be fine for my 1988 CBR 400?
Now if i'm changing the oil would it be best to get more than just 1 litre? I'm not sure how much the engine holds.
Riding as fast as you can sounds like a good speed to me
1988 Yamaha DT 50 > 2004 Motorhispania RYZ 50 > 1988 Honda CBR 400
DrDonnyBrago
PostPosted: 11:54 - 03 Jun 2010    Post subject: Reply with quote
If that is the correct grade as listed in your manual/found online (i.e. 10w/40) then yes that will be fine. You will need considerably more than 1l though, somewhere around 3-4 litres I would imagine.
Edit: just checked it is the correct grade Thumbs Up .
ashwell-09
PostPosted: 14:28 - 03 Jun 2010    Post subject: Reply with quote
Yes it's 10w 40 the engine uses.
I only drained out just under one litre and put back in one full litre, it's just about at the right level, may have to get some more though just to be safe
PostPosted: 14:37 - 03 Jun 2010    Post subject: Reply with quote
No way should a CBR400 only have 1 litre of oil in it. Only figure I can find is 3.4 litres for a later CBR400RR
If 1L is all it has taken to get it back up to the full mark then that suggests you didn't drain all the old oil out.
Mr.Everready
PostPosted: 14:53 - 03 Jun 2010    Post subject: Reply with quote
Are you checking the oil level while the bike is sat up right ? ie not on the side stand.
DrDonnyBrago
PostPosted: 15:12 - 03 Jun 2010    Post subject: Reply with quote
The new filter alone will hold about 300 ml, no chance in hell the whole bike takes 1 l !!!!!!!!!
When you took the drain plug out how long did you wait? If the bike was leaning away from the drain plug or you had it on a centre stand when you drained then you could potentially not have emptied it all off...
Something like the pic attached Thumbs Up .
Either way, a lot more than 1 l should come out.
After you have drained and refilled by the correct amount, remember to check and top up after running the engine for a bit to take into account the oil used to fill the filter.
hondapartsman
PostPosted: 20:53 - 04 Jun 2010    Post subject: Reply with quote
Right oil but damned expensive. Granted I get some staff discount but I can get four litres for not much more than 20. No wonder they call in Halfrauds.
In the end all comes back to the beginning
herulach
PostPosted: 22:53 - 04 Jun 2010    Post subject: Reply with quote
Asda have 2ls of 10w40 on 3 for £10. I had a quick look at the back of the bottle and the ratings are the same A3/B3 iirc.
YBR 125>FZS600
hondapartsman
PostPosted: 08:21 - 05 Jun 2010    Post subject: Reply with quote
Yes but is is semi synthetic, you can get ordinary 10w40 intended for cars cheaply but it'll not last in a bike gearbox, lose grade and be useless really after not too long. I learned that hard way, a semi synthetic is the minimum you need, even one not listed as for bike use. I've used that for years, although not much cheaper than proper bike oil saves a few quid which you need to do when you have about a tenner a week to run your bikes on.
Paxovasa
PostPosted: 08:49 - 05 Jun 2010    Post subject: Reply with quote
Found this which backs up what everyone has said about the oil capacity of been 3.4 litres.
"First manufactured in 1988 the Honda CBR400RR, or 'BabyBlade', is the smaller sibling of ... The CBR400RR engine was a development from that of the CBR400 Aero, ... Engine oil capacity at oil filter change - 3.4 litres"
herulach
I'm looking at the bottle now, it quite clearly says semi synth on it. The only oil you need to avoid in bikes is one with friction modifiers (magnatec, mpg improving kind of stuff) cos it balls the clutch up.
YBR 125>FZS600
The last post was made 16 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 70.02 Kb
