GS500 DIED
ssruk
PostPosted: 13:33 - 03 Jun 2010    Post subject: GS500 DIED Reply with quote
hi there my gs 500 was on a run and it lost power and died up untill this point it ran fine no sign of anything starting to go its only been rebuilt 1000 ish ago just past mot all of 2 weeks ago it wont start now and when i say lost power i mean it was like there was no trottal and no tick over any know whats up with her
Ichy
PostPosted: 13:41 - 03 Jun 2010    Post subject: Reply with quote
Fuel starvation or loss of spark.
Is it running now?
DrDonnyBrago
PostPosted: 14:08 - 03 Jun 2010    Post subject: Reply with quote
When you say rebuilt... what was rebuilt exactly?
When you try and start it does the starter motor kick over? Does the engine catch then die or nothing at all?
ssruk
PostPosted: 14:55 - 03 Jun 2010    Post subject: Reply with quote
it sounds like it should be starting but dont catch iv just put new plugs in and no not helped the hole bike was rebuilt striped every nut and bolt on the bike thats how i know thats old parts as there is non
D O G
PostPosted: 14:59 - 03 Jun 2010    Post subject: Reply with quote
You may have a problem with the main relay, located just below the seat on the RHS, under the panel. If you have a bad contact there, for example if it is badly corroded then it will cut all power - it's essentially the route of the electricity to the motor as a whole.
It's like turning off a switch - it just dies, immediately, no spluttering, nothing. You wont have a starter motor, or anything.
I would be inclined to whip off that panel and have a look at the relay - just trace the big red wire coming off the battery, the cotton reel shaped thing with the big 20A fuse in is the relay and may be the source of your trouble.
It happened to mine several times until I discovered the (fairly common) problem and clened up the corroded connections and dodgy wiring around the relay.
ssruk
PostPosted: 15:24 - 03 Jun 2010    Post subject: Reply with quote
fuse was 1st thing i tryed i still get lights on dash and all out side lights are fine head brakes blinnkeds and so on its just engein power
T1z3R
PostPosted: 16:12 - 03 Jun 2010    Post subject: Reply with quote
well its not the starter relay then. its the culprit on my GS and was stripped and cleaned last night and will be refitted tonight.
you need to check simple things. are you getting a spark at both plugs? are you getting fuel to both cylinders? are you getting compression?
without either one of these you wont have a running bike.
duck my sick!
ssruk
PostPosted: 18:37 - 03 Jun 2010    Post subject: Reply with quote
plugs are new today got some new ones as i was in bike shop getting a some chain oil so not them and yes both spark fuel was checked and there is unburned fuel in both carbs and underspark plugs will cheack compreson later after work
(02)hyosung crusie 2(sold) (89)cbr 600f (91) gs500ex
ssruk
PostPosted: 18:29 - 06 Jun 2010    Post subject: Reply with quote
it lives turn out all it was the fuel tap got stuck half on so was not getting the fuel to fire or keep running
The last post was made 16 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 60.28 Kb
