Clutch Plates - Which Order?
instigator
PostPosted: 12:40 - 02 Jun 2010    Post subject: Clutch Plates - Which Order? Reply with quote
I have a K1 GSX-R 1000, standing at roughly 46,000 miles.
Originally, the clutch was awful and it would slip immediately which I put down to the inherent design issue which was fixed on the K2. I resolved this by buying a wave washer and end friction plate from a K2. This worked perfectly but I still couldn't nail it from the lights so being that it was the original clutch, I knew it would need a entire replacement eventually.
Fast forward today and I have an EBC SRK Series clutch kit sitting on my desk, consisting of Friction discs, Steel discs and new springs. This was supplied direct from Wemoto.
The steel plates were supplied in a package which was nice so I can safely assume they're 'in the right order'. However, the friction discs weren't and as such, I'm not sure if they are in the correct order. There are ten discs, all the same colour and from the naked eye, all seem the same shape & diameter.
So....where do I take it from here? People always harp on about 'having them in the right order' but I can only presume this is the simple friction>>metal>>friction>>metal>>friction order and not in relation to the order, front to back, of the friction plates.
Can anyone advise? Same on the notches on the friction discs...there are three notches on the tabs which stick out....do they all line up or are they staggered in order? Fuck knows....grrr...The workshop manual states a specific order but I can't differentiate between the friction discs as they're all green....not the '8 green' and '2 brown' as the manual details. See attachment.
And if anyone knows the way in which the wave washer fits in, right at the back, then that'd be great too as even though it's in already, I need to validate it whilst the clutch is out.
Question Thumbs Up
DrDonnyBrago
PostPosted: 12:50 - 02 Jun 2010    Post subject: Reply with quote
In the PDF, under the diagram of the plates the NOTES says it is not required that you use the other type plates when replacing the clutch as this is a factory setting - I assume this means that you are ok to use the same type plate throughout hence yours all look the same.
I know nothing about clutches though so I'm sure someone else will have something to add Thumbs Up .
HTH.
Phoenix
Twisted Firestarter
PostPosted: 12:57 - 02 Jun 2010    Post subject: Reply with quote
Looking at your manual all your replacement steel plates should be identical so any order, the friction will all be identical except for two which go at the ends, there's usually a visible difference in size of the friction material blocks on it or the inner diameter is slightly larger usually.
instigator
PostPosted: 14:26 - 02 Jun 2010    Post subject: Reply with quote
Can't see any difference at all myself but I have a digital micrometer at home so I guess that's my best bet. But I really can't see any difference at all.
Does anyone know about the notches on the tabs which stick out of the friction discs. They have semi circular notches cut out of them. Unsure if they are supposed to be lined up together or do they go in 'all higgety piggelty'?
jimspeed
PostPosted: 23:32 - 03 Jun 2010    Post subject: Reply with quote
would the notched bits not all go in to make a line, thats what i would think anyway as maybe its to do with the balancing etc as they are going to be spinning quite quickly.
maybe.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
instigator
PostPosted: 23:45 - 03 Jun 2010    Post subject: Reply with quote
Fuck knows mate. Laughing
I just jammed it in, any old order as I couldn't measure or tell the difference between any of the friction plates or steel plates. Seems to be working fine thus far.
Thanks all.
PostPosted: 00:11 - 04 Jun 2010    Post subject: Reply with quote
Should be ok. Never done a gixxer thou clutch but on a 'busa there are two thicker plates that go in the middle of the pack.
The last post was made 16 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 53.89 Kb
