| X9-rider |
 X9-rider Trackday Trickster
| cb1rocket |
 cb1rocket World Chat Champion
| pepperami |
 pepperami Super Spammer
 Posted: 11:50 - 25 May 2010 Post subject: |
i`m just guessng here? .... but it sounds like you did`nt tighten everything up as per spec when you reset the valves?.
it sounds like something has worked it`s way loose?
on the other hand! is it the right air filter? and is it put in right?........ because if that is collapsing when you are running the bike or opening the throttle, that will affect your power output.
these are just a couple of ideas that i would look at if that bike was mine.
hope it helps  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| X9-rider |
| Mudskipper |
 Mudskipper World Chat Champion
 Posted: 20:55 - 25 May 2010 Post subject: |
Are they locknut tappets on the valves?
I once adjusted mine, was sure I'd tightened the locknuts properly but I got the rattling and then massive loss of power.
When I had a look inside, one of the nuts had come off and got crushed.
I hope it's not as bad as that for you.  ____________________ CBR125|||GSXR400|||CBR400|||CBR400|||CB250RS|||GSXR750|||CB250RS
"You're clumsy, you eat too much and you behave like a 12 year old boy. But you know what? Every once in a while, you find a thumb." |
| X9-rider |
| wizzzard |
 wizzzard World Chat Champion
 Posted: 10:52 - 26 May 2010 Post subject: |
All I can think from past experience is when I had slightly bent valves ( just before they became very snapped valves ) and they wouldnt close fully. Lost power and rattled in the guides. If you need a second opinion or another set of hands I'm not to far from you. ____________________ And did you exchange a walk on part in the war for a lead role in a cage?
Zeitgeist / Addendum / Moving forward |
| X9-rider |
| X9-rider |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| wizzzard |
 Posted: 11:27 - 04 Jun 2010 Post subject: |
Hi Alex, if I'm right did you not prang the bike a few weeks ago?
Just looking for other reasons for a noise to be there  ____________________ And did you exchange a walk on part in the war for a lead role in a cage?
| N cee thirty |
 N cee thirty Banned
| cb1rocket |
| X9-rider |
| Frost |
 Frost World Chat Champion
| N cee thirty |
 N cee thirty Banned
| Frost |
| X9-rider |
 Posted: 22:20 - 05 Jun 2010 Post subject: |
| Quote: | Tappy and from the top = valves |
Yes but there bang on 0.08 clearance so cant be vavles, unless worn ? also the bike starts first kick, and the bike does 60mph so no lost in power there.
| Quote: | Wirring and from one side = cam chain. |
From what i been told it has not got one its push rode, so no cam.
| Quote: | Did you actually change the head gasket, or did you do the rocker cover seal? |
When you take the top off the engine to get to the valves, on the cover there is a grove that goes around filled with a Black rubber seal, that's what been replaced ( gasket ).
| Quote: | First things is, does the noise get worse with engine revs, or with road speed? If road speed its likely to be the speedo drive not being in properly. |
Both really. |
| X9-rider |
The last post was made 16 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
