Yamaha rxs issues
Carvel
PostPosted: 16:22 - 04 Jun 2010    Post subject: Yamaha rxs issues Reply with quote
Hello
im having a few problems with my yamaha rxs100. Firstly the exhaust is leaking from where the downpipe and the exhaust connect. The manual states 'the sealing ring at the gland nut join'. There doesn't seem to be one in there and i cant seem to find mention of one for sale anywhere, only the one that seals the exhaust at the barrel. Is there anything else i could do to stop it leaking.
Also the bike will start and run ok, but after riding it for a few minutes it will cut out, as if it has run out of petrol. It wont start straight away but left for a few minutes will start and run perfectly.Any ideas? Im thinking fuel starvation, maybe temperature related but i have no idea where to start tbh. Sad
Any help would be much appreciated Thumbs Up
Ollie
27cows
PostPosted: 20:43 - 04 Jun 2010    Post subject: Reply with quote
My current pipe is actually missing the sealing ring between downpipe and exhaust too. Bike runs fine, just blows very slightly. I keep meaning to order a new sealing ring. You can definitely buy them from Yam dealers, I've got them in the past.
The cutting out problem is a weird one and not one I've encountered on my RXS. Go through the usual checks - replace plug, make sure the HT lead is on tight not corroded, clean carb and check float height, make sure there are no air leaks, decoke the baffle. Most likely a carburation problem, as you say.
SW Motech Shop UK
PostPosted: 21:25 - 04 Jun 2010    Post subject: Reply with quote
I had an RXS fifteen years ago and it would cut out after a while just like yours and re start after a short while. It turned out it was heat seizing and needed a rebore and new piston. It would be worth the price of a gasket set just so you can check.
https://www.motorcycle-road-and-race.co.uk and https://www.sw-motech-shop.co.uk/ and https://www.motorcycle-luggage.co.uk/
Carvel
PostPosted: 00:46 - 05 Jun 2010    Post subject: Reply with quote
sweet cheers 27cows ill give yamaha a call tomorrow Thumbs Up . Its got a new plug in it and the HT lead is fine. The carbs been off and cleaned twice and checked float height so i dont think its that but its possible. I think it does have an air leak since i took the carb off the carb off the other day because the revs take a long time to fall(I think this points to an air leak), but it was cutting out before this started happening.
I dont think its heat seizing because the engine will turn over freely as soon as it cuts out, although it has been seized by the previous. I put a new piston, small end etc in it and it seems fine, not noisy, good compression and runs ok(till it cuts out of course Sad )
bit puzzled really
cheers for the help btw Thumbs Up
Ollie
lukamon
PostPosted: 02:50 - 05 Jun 2010    Post subject: Reply with quote
take the fuel pipe off the carb and see how fast it drains from the tank? could just be a blocked pipe.
killa wrote: Im an ass man myself
carper84
PostPosted: 15:41 - 05 Jun 2010    Post subject: Reply with quote
Mines the same as cows, i dont have one in either. When i first got my rxs it was leaking a bit too, i ended up getting some exhaust sealant stuff and its been fine. If you have too much trouple getting a gasget/ring pm your address and i'l send you one. Iv got a couple of spares as they was only 50p each Very Happy
I dont know why i would be cutting out, do as mentioned before and check the usual suspects
Good Luck Very Happy
Its a way of life!!
smegballs
PostPosted: 17:48 - 05 Jun 2010    Post subject: Reply with quote
Theres no need to take the head off and need a new head gasket.
You can quite happily undo the barrel and just slide the barrel off the piston.
That way you only spend 2.50 on a base gasket.
Carvel
PostPosted: 20:46 - 05 Jun 2010    Post subject: Reply with quote
Took the bike out again today and its still doing it Sad . I took the plug out afterwards and it was very wet.
Took the fuel pipe off and its flowing nice and fast. Thumbs Up
Carper84 thanks for the offer mate might take you up on that one. Thumbs Up
Also its getting harder to start. It never used to need choke and used to start first kick every time but now it needs choke and takes a few kicks. It seems to run a bit lumpy now aswell if that makes sense.
Also it ticks over fine but if you rev it neutral, instead of falling back down to tickover the revs just fall until it cuts out.
cheers for the help ladies Wink
Ollie
27cows
PostPosted: 21:49 - 05 Jun 2010    Post subject: Reply with quote
You have the mixture screw set up correctly?
I've got a weird carb that, though there's nothing apparently wrong with it, won't behave no matter what I do. Wondering if that's what you have there. With mine, the bike will start fine, no problem, but if you try to start it again within about half an hour - no chance.
Carvel
PostPosted: 22:09 - 05 Jun 2010    Post subject: Reply with quote
27cows Its funny you should that because when I bought the bike the mixture was only screwed a quarter turn out (manual says 2 and a quarter) I changed it to the correct setting and it made no difference whatsoever Shocked . could this be something to do with it.
Ollie
27cows
PostPosted: 07:54 - 06 Jun 2010    Post subject: Reply with quote
Ollie
Should be 1 and a quarter to 1 and a half turns out. I always have mine 1 1/2, seems to work well like that. If you have it 2 and a quarter out, it'll make a big difference. Might not always be obvious at first, but with the mixture that far out, it'll probably cause the motor to play up. Surprised it even ran only a quarter out Shocked
Carvel
PostPosted: 19:31 - 06 Jun 2010    Post subject: Reply with quote
I changed the mixture screw to 1 and a halfs turns out. The bike runs sweet as a nut pulling strongly Cool but it still cuts out Sad . Only got less than half a mile this time aswell.
The last post was made 16 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.4 - MySQL Queries: 13 - Page Size: 74.73 Kb
