erratic idle.
X9-rider
PostPosted: 21:51 - 06 Jun 2010    Post subject: erratic idle. Reply with quote
Well just got in and the bike is hard to start, and the idle is erratic. I stooped at a junction after the erratic idle stalled the bike, and toke lots of kicks to get it going.
Whats next ? or should i do, got some money spear to spend on it, so what should i have done at the dealers ? looking to spend no more then 150.00 on the CG to get right ?
Ichy
PostPosted: 22:11 - 06 Jun 2010    Post subject: Reply with quote
Thousand and one reasons why but its always worth changing the spark plug just in case.
If you up for it then give the carb a clean out.
CarlosCBR
PostPosted: 22:12 - 06 Jun 2010    Post subject: Reply with quote
Try adjusting the idle mixture screw and give the carb a good clean inside.
X9-rider
PostPosted: 22:21 - 06 Jun 2010    Post subject: Reply with quote
I adjusted the idle screw but bike still idles abit erratic. the spark plug is new only been in a few weeks but if its a good idea then ill buy a new one.
Ichy
PostPosted: 22:32 - 06 Jun 2010    Post subject: Reply with quote
Plug is unlikely to fail in that amount of time. Carb clean would be the next thing to look at.
What is the bike like when your off idle? Accelerating?
X9-rider
PostPosted: 23:07 - 06 Jun 2010    Post subject: Reply with quote
once going, its all good, its just when still. with some of the problems from day one, i am thinking of pooping it eBay and going back to the X9.
when iam having the piston rings done ill have carb cleaned too.
Noxious89123
PostPosted: 23:23 - 06 Jun 2010    Post subject: Reply with quote
What is the highest and lowest it idles at?
500 ~ 900 rpm ?
900 ~ 1200 rpm??
1200 ~ 1500 ?
How erractic is it?
If it's really low, it could just be the idle is set to low, and it's almost stalling itself.
Is the choke working properly? Not stuck on / off?
X9-rider
PostPosted: 11:30 - 07 Jun 2010    Post subject: Reply with quote
Noxious89123 : The choke works fine, and the idle is set at the correct setting, i have even set it bit higher to compensate.
As for RPM the 20yr old CG doesn't have a Rev counter.
el_oso
PostPosted: 11:44 - 07 Jun 2010    Post subject: Reply with quote
pilot jet may be blocked.
Duke 390
Car: Jeep Wrangler 4.0L
X9-rider
PostPosted: 12:11 - 07 Jun 2010    Post subject: Reply with quote
Looks like i have got all the answer guys. Clean the carb out and get new piston rings as bike burns oil.
Ichy
PostPosted: 13:01 - 07 Jun 2010    Post subject: Reply with quote
Might as well check the valves while you have it a part.
pepperami
PostPosted: 15:15 - 07 Jun 2010    Post subject: Reply with quote
they can fail from day one! Shocked ........ just been doing the finishing touches to an old XS400, and we could not get it to run right for love or money Twisted Evil until we changed the brand new plugs with another set of brand new plugs Confused now it`s one step closer to running right Smile
The last post was made 16 years, 94 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 71.53 Kb
