Starter motor or solenoid?
piaggiox9
PostPosted: 20:06 - 07 Jun 2010    Post subject: Starter motor or solenoid? Reply with quote
Hi, this is my second post now but with a new problem.
Hope any of you guys can help?
So, I went away for a few days and my bike was left at home. When I came back to start it for work it wouldn't turn over.
All I got was a clicking noise from the solenoid. I spent two hours taking the bike apart and got the starter motor out. I gave it a good clean. Put it all back together and still only clicking.
What I would like advice on is do you think its still something to do with the starter or solenoid?
I measured across the battery and it read 13.3amps so this is enough for the starter.
Tried to read at the point of the starter motor and started the ignition. But wouldn't read anything.
Do I need a new starter motor? Solenoid? or all of the above?
Can't wait for your reply's as im really stumped!
Thanks
Jon
Paxovasa
PostPosted: 20:11 - 07 Jun 2010    Post subject: Reply with quote
Try charging the battery or jumping it from another battery Thumbs Up
oops, I should read the whole post before replying Embarassed
piaggiox9
PostPosted: 20:20 - 07 Jun 2010    Post subject: Reply with quote
Paxovasa, cheers, That was my first attempt to get it started. But battery is fine.
Thanks for the reply tho.
dobby
PostPosted: 08:56 - 08 Jun 2010    Post subject: Reply with quote
try another starter relay they are only about a 10er, i would probably guess its that
iooi
PostPosted: 09:15 - 08 Jun 2010    Post subject: Reply with quote
Try tapping the starter motor with a hammer to see if its simply got stuck.
Or you could take it off and then wire it up to see if it turns.
My money is on its simply got stuck Thumbs Up
PostPosted: 10:21 - 08 Jun 2010    Post subject: Reply with quote
Have you actually charged the battery?
It sounds very much like a flat battery.
If it isn't, the solenoid's not broken since you can hear it clicking so the fault must lie with the starter motor......
mr rip
PostPosted: 10:32 - 08 Jun 2010    Post subject: Reply with quote
depending on what type of solenoid you have either put a spanner across the terminals or take the leads off & touch them together
if the motor spins when you do this then the solenoid is shot, if it doesn't spin then the starter is at fault
never criticise a man until you've walked a mile in his shoes, then when the muck hits the fan you'll be a mile away & you'll have his shoes
PostPosted: 11:21 - 08 Jun 2010    Post subject: Reply with quote
The effect does sound just like the battery is wrecked. The reading over the battery should be a touch over 12V with the engine off (NOT amps).
All the solenoid does is connect power directly from the battery to the starter motor. As such you can easily bypass it with a jump lead. If the bike starts doing that then you know the solenoid is dead.
piaggiox9
PostPosted: 19:16 - 08 Jun 2010    Post subject: Reply with quote
Hi, thanks for all the reply's.
Ok, so I jumped the relay and the starter motor spun.
Bought a new relay and the starter motor worked. BUT....
The bike wont actually fire up. Read the battery and its only giving out 11.6 V . So I have it on charge as i write this.
I will let you know of the outcome.
Thanks again for all the helpful advice.
piaggiox9
PostPosted: 19:53 - 08 Jun 2010    Post subject: Reply with quote
No it dint work. Still the same, starter running but engine not firing up.
Who knows the answer? Please reveal, thanks
Jon
PostPosted: 20:34 - 08 Jun 2010    Post subject: Reply with quote
Are you getting a spark.
piaggiox9
PostPosted: 21:07 - 08 Jun 2010    Post subject: Reply with quote
Kickstart - how can you tell?
Thanks
Jon
PostPosted: 21:30 - 08 Jun 2010    Post subject: Reply with quote
Take the plug out. With it in the plug cap with the end of the spark plug held against the engine (and metal part of the engine) crank the engine over. You should see the spark.
Note that if the plug cap is knackered you might get a shock from it when cranking the engine over.
The last post was made 16 years, 94 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 75.86 Kb
