top end swap
matt black it
PostPosted: 12:19 - 08 Jun 2010    Post subject: top end swap Reply with quote
Hello,i have a kawasaki LTD 454,can i swap the top end from an LTD 500 straight onto it and will it run?
thx in advance
hmmmnz
PostPosted: 05:27 - 09 Jun 2010    Post subject: Reply with quote
short answer is no.
the 454 has a bore and stroke of 72.5 x 55.0 mm
and the 500 is 74.0 x 58.0 mm
so you have a longer stroke on the 500, which is where the problems would occur even if the barrels etc bolted to the bottom end,
the piston would come up 1.5mm short
you may be able to get a taller piston to compensate, who knows,
that would make it 74x 55mm so a 473cc
probably easier to get a en500 engine and try and bolt that in rather than changing top ends
the humans are dead
I kick arse for the lord
temeluchus
PostPosted: 06:58 - 09 Jun 2010    Post subject: Reply with quote
The Cylinder head MIGHT swap. MIGHT.....
matt black it
PostPosted: 10:43 - 09 Jun 2010    Post subject: Reply with quote
Thanks for the answer's.I thought it would be a bit too good to be true.I have been offered the 500 lump that the top end is on but the gearbox is knackered,thats why i thought i might get away with swapping top end's.
Thanks again for taking the time to answer. Thumbs Up
hmmmnz
PostPosted: 11:43 - 09 Jun 2010    Post subject: Reply with quote
its not to say its impossible,
if i had 2 gubbed engines, 1 with a good bottom end and 1 with a good top end,
and i didnt mind spending a bit on pistons,
then i would find a way of doing it,
but the reality of it is, that its probably cheaper and easier to buy a whole new engine
the humans are dead
MaybeGuy
PostPosted: 11:49 - 09 Jun 2010    Post subject: Reply with quote
you could always get the barrel skimmed the distance the piston is short. Wouldnt cost much if you cant do it yourself.
The last post was made 16 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 47.71 Kb
