| matt black it |
 matt black it L Plate Warrior
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 05:27 - 09 Jun 2010 Post subject: |
short answer is no.
the 454 has a bore and stroke of 72.5 x 55.0 mm
and the 500 is 74.0 x 58.0 mm
so you have a longer stroke on the 500, which is where the problems would occur even if the barrels etc bolted to the bottom end,
the piston would come up 1.5mm short
you may be able to get a taller piston to compensate, who knows,
that would make it 74x 55mm so a 473cc
probably easier to get a en500 engine and try and bolt that in rather than changing top ends ____________________ the humans are dead
I kick arse for the lord
| temeluchus |
| matt black it |
 Posted: 10:43 - 09 Jun 2010 Post subject: |
Thanks for the answer's.I thought it would be a bit too good to be true.I have been offered the 500 lump that the top end is on but the gearbox is knackered,thats why i thought i might get away with swapping top end's.
Thanks again for taking the time to answer.  |
| hmmmnz |
 Posted: 11:43 - 09 Jun 2010 Post subject: |
its not to say its impossible,
if i had 2 gubbed engines, 1 with a good bottom end and 1 with a good top end,
and i didnt mind spending a bit on pistons,
then i would find a way of doing it,
but the reality of it is, that its probably cheaper and easier to buy a whole new engine ____________________ the humans are dead
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 11:49 - 09 Jun 2010 Post subject: |
you could always get the barrel skimmed the distance the piston is short. Wouldnt cost much if you cant do it yourself. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
The last post was made 16 years, 105 days ago. Instead of replying here, would creating a new thread be more useful? |
