Holts Tyre Weld Or Tyre Slime?
Ben_m
PostPosted: 17:15 - 08 Jun 2010    Post subject: Holts Tyre Weld Or Tyre Slime? Reply with quote
Which one would you go for? Ive heard the slime can cause balancing problems but would be better than the tyre weld as its a prevention not a cure. Has anyone got any experience of either of these?
Yamaha Fazer FZS600 2003 ¦ Peugeot 206 GTI 180BHP 2003 ¦ BMW 323i SE
Mister James
I want to believe!
PostPosted: 17:27 - 08 Jun 2010    Post subject: Reply with quote
I've never used the slime but like the idea.
I've previously run the rear tyres of both my old scooter and my KLE 500 for hundreds of miles on Tyre Weld after suffering punctures/flats.
I went up to motorway speeds on the KLE (which has tubed tyres so slightly different case to normal sportsbike tyres) with no ill effects.
The scooter's tyre was over inflated and thus rock hard, but again served its purpose until it was nicked - I hope the back-breakingly hard suspension squashes their nuts and makes them sterile!
My only concern with the slime is that you wouldn't know when your tyre has been compromised.
If you carry a tin of Weld around with you, when you get a puncture you can find and assess the damage to the tyre and make a judgement about whether it's safe to re-fill and use.
Poseidon
PostPosted: 17:31 - 08 Jun 2010    Post subject: Reply with quote
I've used tyre weld before on my quad bike (suzuki LT250) which I only ever used in old quarries etc. Never had to replace the tyre despite it taking serious punishment every weekend! Tyre weld gets the Thumbs Up from me.
Cant comment on slime though.
1977 Honda CG125
SlimRick
PostPosted: 18:13 - 08 Jun 2010    Post subject: Reply with quote
Been using tyre-weld in a rear tyre on my Audi for approx 6 months / 8000 miles now. Gets my vote.
hellobaby
PostPosted: 18:30 - 08 Jun 2010    Post subject: Reply with quote
used the slime on the back tyre of my hornet after a bad puncture repair from the garage, worked a charm.
Also used it for my mates sc front tyre after he got a screw put in it leaving a significant puncture, again it worked as advertised. I recommend it.
CBT - 10/05/08, Theory 7/05/08
Ben_m
PostPosted: 19:05 - 08 Jun 2010    Post subject: Reply with quote
Did you put the slime in after your mate got a puncture? Don't fancy using it unless I have to.
hellobaby
PostPosted: 23:51 - 08 Jun 2010    Post subject: Reply with quote
Yep, put it in a completely flat tyre and pumped it up, its been about 3 months and I ain't heard him complain yet, so for the £8 or whatever it is I certainly found it a good buy.[/quote]
TheDonUK
PostPosted: 01:17 - 09 Jun 2010    Post subject: Reply with quote
I hear bad things about the slime from tyre fitters. Plus as has been said you would never know if you had a puncture Shocked
I used the Tyre-Weald Once, worked perfectly, it said take it easy but i was comfortable caining it for the next few days...
ws4936
PostPosted: 09:53 - 09 Jun 2010    Post subject: Reply with quote
I thought about this last night, while watching a police stop, kind of programme, when they were trying to use a stop stick on a stolen vehicle. Confused
If everything seems under control, you're just not going fast enough.
Walloper
PostPosted: 15:06 - 09 Jun 2010    Post subject: Reply with quote
I use Puncturesafe/Ultraseal not Tyre weld.
Tyre fitter hate cleaning out tyre and rims that have sealant in them. But they should clean out the tyre and rim to repair or refit anyway. I would not complain if someone wants to pay me to change tyre I will do it happily.
You will know if you have a puncture when ultraseal/puncturesafe sealant is in the tyre as some will ooze out before plugging the leak much the same as a cut finger does. It will be seen on the tyre at the hole/s and possibly on the hugger or under the seat even if you've been riding in the rain.
It is a permanent repair.
I don't think sealant charged tyres would survive a law enforcement imobilizer such as 'The Stinger' the compound is designed to accomodate holes up to 1/4" and I think the stinger spikes are bigger than that.
Possibly the stinger also shreds the tyre too.
I am a card carying member of the Tyre Sealant party. Smile
NickD
PostPosted: 15:16 - 09 Jun 2010    Post subject: Reply with quote
Arrow The good - I used Slime on an already punctured tyre wtih the initial idea of getting to a tyre fitters and having it repaired properly..... As often happens I never got around to it and ended up doing 4k on the slime repair with no ill effects, loss of pressure or balance issues.
Arrow The bad - Apparently the slime causes the wheel to fur a bit. When I had the replacement tyre fitted the fitter cleaned up the wheel and put the new tyre on, but I found it flat a couple of weeks later. I took it back and he removed and re fitted it after fettling the wheel again, which had started to fur. Exactly the same happened a couple of months later too. To be fair I've had no problems since though.
I was only doing what it said on my licence officer....
Tear along the dotted line!
The last post was made 16 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 71.09 Kb
