suzuki ay50 problems
kingjosh
PostPosted: 17:02 - 08 Jun 2010    Post subject: suzuki ay50 problems Reply with quote
I was riding down a hill when it cut out,i thought maybe running low on petrol,so filled it back up.
now it revs but doesent start.
im shit scared its broke i only had it 1 week
help please
kingjosh
PostPosted: 20:08 - 08 Jun 2010    Post subject: Reply with quote
help
Paxovasa
PostPosted: 20:11 - 08 Jun 2010    Post subject: Reply with quote
What do you mean it revs, but doesn't start?
27cows
PostPosted: 20:46 - 08 Jun 2010    Post subject: Reply with quote
Maybe a duff/fouled plug.
kingjosh
PostPosted: 22:04 - 08 Jun 2010    Post subject: ,. Reply with quote
when i try kick starting it,it makes a rev noise,but sounds like it cant tick over.
It started when i was going down a hill and it just cut out,i restarted the engine,then it cut out 2 mins later,and then it wouldnt start back up.
so i filled it up with petrol
still not working.
Paxovasa
PostPosted: 22:18 - 08 Jun 2010    Post subject: Re: ,. Reply with quote
still not working.
Sounds like the engine is turning but not firing up, as has been suggested check the plug and the HT lead (the lead that attaches to the top of the plug) Thumbs Up
kingjosh
PostPosted: 22:19 - 08 Jun 2010    Post subject: Reply with quote
Im a complete rooky,what do you mean by plug Rolling Eyes
and could it be that i ran out of 2 stroke oil?
Paxovasa
PostPosted: 22:23 - 08 Jun 2010    Post subject: Reply with quote
Plug - spark plug.
Did you actually run the bike without 2 stroke?
If you did then you may have fucked the engine Shocked
kingjosh
PostPosted: 11:48 - 09 Jun 2010    Post subject: oh no Reply with quote
Im not 100 percent sure its out of oil,i look in there and cant see some in there.
the thing is my gauge doesent work.
So would putting more oil in there fix this problem
Paxovasa
PostPosted: 11:54 - 09 Jun 2010    Post subject: Reply with quote
You should regularly top the 2 stroke reservoir up.
Top it up and cross your fingers that you haven't fucked the engine.
kingjosh
PostPosted: 12:57 - 09 Jun 2010    Post subject: Reply with quote
now im shit scared
Rolling Eyes
Paxovasa
PostPosted: 14:16 - 09 Jun 2010    Post subject: Reply with quote
Bleed the oil through to the pump, before starting the bike.
kingjosh
PostPosted: 14:40 - 09 Jun 2010    Post subject: Reply with quote
thanks for your reply,how do i do so?
Paxovasa
PostPosted: 15:06 - 09 Jun 2010    Post subject: Reply with quote
Fill up the reservoir with 2 stroke oil, there should be either a bleed nipple or a screw with a rubber washer on the pump. Undo it and then wait for the oil to get forced through and the air to get forced out. When there is no more air tighten either the nipple or the screw up. Check how tight it should be in a manual. Thumbs Up
kingjosh
PostPosted: 17:42 - 09 Jun 2010    Post subject: Reply with quote
I will go to halfords tommorow and buy some 2 stroke oil.
and will this stop my engine being broke?
Paxovasa
PostPosted: 17:45 - 09 Jun 2010    Post subject: Reply with quote
Before it stopped, did the bike lose power? As is it didn't go as fast as it usually did, for a few miles?
27cows
PostPosted: 18:49 - 09 Jun 2010    Post subject: Reply with quote
If the engine still turns over, it's very unlikely you're out of 2 stroke.
Come on, you piss taking buggers, don't you remember being a raw n00b? Neutral
kingjosh
PostPosted: 19:15 - 09 Jun 2010    Post subject: Reply with quote
yes Paxovasa
Paxovasa
PostPosted: 19:19 - 09 Jun 2010    Post subject: Reply with quote
If it lost power like I described, then you ran the engine without any 2 stroke oil.
I hope I am wrong with the above.
kingjosh
PostPosted: 10:22 - 10 Jun 2010    Post subject: Reply with quote
oh shit!
does this mean my engines going to be broke.
Will bleeding the engine fix it?
Paxovasa
PostPosted: 10:31 - 10 Jun 2010    Post subject: Reply with quote
kingjosh wrote:
oh shit!
Bleed the engine?
27cows
PostPosted: 11:04 - 10 Jun 2010    Post subject: Reply with quote
kingjosh wrote:
oh shit!
First thing you need to do is locate the oil tank and see if there's any oil left.
If there's not and the engine hasn't seized solid, the chances are it'll be OK once you've bled the oil pump. This involves putting oil in the oil tank, removing a screw from the pump and basically waiting until oil emerges from it - oil will then be getting through when you restart the engine.
The last post was made 16 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 122.54 Kb
