Gsf 1200 electrical help
suzy2869
PostPosted: 07:12 - 09 Jun 2010    Post subject: Gsf 1200 electrical help Reply with quote
Hi my B12 was running ok the other day and someone flicked the run/killswitch off and the engine died as expected, when I switched it back on the neutral and oil lights came on soon as I pressed the start switch there was a click and the lights all went out no power to ignition lights or alarm lights came back on after about 10 mins but same thing happens whenever I press the start switch any ideas please ????
Paxovasa
PostPosted: 08:45 - 09 Jun 2010    Post subject: Reply with quote
Sounds like a bad connection.
PostPosted: 09:33 - 09 Jun 2010    Post subject: Reply with quote
Have you checked the fuses?
suzy2869
PostPosted: 15:46 - 09 Jun 2010    Post subject: Fuses Reply with quote
Hi yeah have checked the fuses I can find the ones under the seat and the 30 amp one on the solonoid
doggone
PostPosted: 16:31 - 09 Jun 2010    Post subject: Reply with quote
Does anything else work - horn, lights?
It sounds like a bad earth which is OK with light load such as your dash lights but when more power tries to flow the connection gives up.
suzy2869
PostPosted: 17:04 - 09 Jun 2010    Post subject: Reply with quote
Yep lights are on not checked horn indicators work just all go out when I go to start it then have to wait for them come back on
suzy2869
PostPosted: 17:54 - 09 Jun 2010    Post subject: Reply with quote
Sorry I stand corrected if I switch lights and or indicators on there's a click and the power goes out then has to reset :0(
Paxovasa
PostPosted: 17:59 - 09 Jun 2010    Post subject: Reply with quote
Sounds like the battery is flat, Stick the battery on charge for a few hours and try again Thumbs Up
doggone
PostPosted: 19:28 - 09 Jun 2010    Post subject: Reply with quote
In a way that makes it easier because there's a general problem with the entire electrics rather than a hard to pin down issue with the starter or switches that stop starter working like on the sidestand.
First thing to check is that you have a really good earth between battery negative and frame.
If you have or can borrow a decent pair of jump leads you can bypass or augment the existing black wire - connect onto some bare metal and see if it will go then.
suzy2869
PostPosted: 19:28 - 09 Jun 2010    Post subject: Thank you Reply with quote
Thank you to everyone with there advice I feel a bit of a twit now lol the earth had come loose on the battery doh :0)
The last post was made 15 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 61.89 Kb
