Turkish old style CG125 copy questions!
621andy
PostPosted: 15:35 - 09 Jun 2010    Post subject: Turkish old style CG125 copy questions! Reply with quote
I've got a Mondial 125UAG, which is basically a Turkish copy of the 80s Honda CG, and is still in production here...
A few questions;
1. What should the tyre pressures be?
2. Were the drum brakes really that crap on the original?! (My dad had one, but never heard him complain-probably he didn't know any better!)
3. It has a habit of backfiring embarrassingly on the overrun- is this just excess fuel or can I adjust summat? There's just been a multiple shooting in town(welcome to the wild west!) and I don't want the trigger happy rozzers getting nervous!
4. How often should I change the oil? It gets quite hot here, and there're a lot of hilly bits. I've just done a change after about 2000km as it was looking black, but I just wondered how often the recommended frequency was back then?
Otherwise it's a good little runaround and is ideal for nipping around town here in the styx Wink
Paxovasa
PostPosted: 15:47 - 09 Jun 2010    Post subject: Reply with quote
Rear drum brake is OK, but front drum brakes Shocked
Does sound like the mixture needs to be adjusted slightly, that should stop the back firing.
2000km seems low to me, I would have thought about 4000 miles between oil changes. But it is up to you, if you want to change sooner it wont harm it Thumbs Up
spanerman
PostPosted: 16:01 - 09 Jun 2010    Post subject: Reply with quote
New shoes abd clean the hub out will make a world of difference to the brakes Smile
Sam.
621andy
PostPosted: 16:07 - 09 Jun 2010    Post subject: Reply with quote
It's CDI, so don't really know what to play with!
Almost exactly the same as the old CG, with the addition of leccy start and the CDI ignition. They're two a penny here, and spare parts sooo cheap Wink Just put on a new exhaust for the equivalent of 30€ including fitting Thumbs Up and that was not the local price either! If I'd sent one of our crew round with it it'd have been even cheaper, but I couldn't be arsed.
Which is the mixture screw? I adjusted the tickover with a screw, but it could just as well have been the mixture Embarassed
I certainly noticed the oil change- gear change is much easier and it runs quieter. With me on it(I'm not wot you'd call slim Laughing ) and the hills as well, I think it's working quite hard, then add on our touring about with the missus on the back, then I think 2000km is reasonable!
Anyway, thanks everyone for the prompt replies!
PS; Just attached a front view...
621andy
PostPosted: 16:09 - 09 Jun 2010    Post subject: Reply with quote
It had new shoes when I bought it! Think they're just full of erm, character. Just like a C90 really, but then so's the top speed Wink
spanerman
PostPosted: 16:16 - 09 Jun 2010    Post subject: Reply with quote
Yup thats right, i have a 2002 model and the brakes are quite good, they just need adjusting and cleaning Smile
Sam.
spanerman
PostPosted: 19:03 - 09 Jun 2010    Post subject: Reply with quote
Use a small driver bit to get to it Smile
https://www.bosch-do-it.co.uk/mam/bosch-pt-centralpool/diy/diyknowledge/lexicon/bit1.jpeg
Like that
Sam.
carvell
Scuttler
PostPosted: 19:12 - 09 Jun 2010    Post subject: Re: Turkish old style CG125 copy questions! Reply with quote
The air cut off valve on the carbs may not be working properly, if it has one.
Gives you something to google for anyway!
Yamaha TDM 850
Moo.
PostPosted: 19:58 - 09 Jun 2010    Post subject: Reply with quote
25 on the front, 29 on the back Wink
Or two up, 29 on the front, 32 on the back Very Happy
Hehe, i have a '77 cg.. i've never had anything other then drums.. dont know any different Very Happy all i can suggest is a milkmans grip!
Wouldnt mind one of those rear racks.. canny find em, none have the right fittings Razz
Oil changes sound about right.. mine tends to get black after a while, but its a cg engine so should run for yonks!
They 12v over there?
A2 Passed 18/6/10
robocog
PostPosted: 21:14 - 09 Jun 2010    Post subject: Reply with quote
you mention a new exhaust fitted...
if there was a leak in the exhaust system it could also cause the over run backfire IME
Worth checking the gaskets are seated and nuts tightened before twiddling the mixture before properly establishing its the mixture at fault!
Regards
Rob
Needs a bigger garage...
hondapartsman
PostPosted: 07:41 - 10 Jun 2010    Post subject: Reply with quote
I think other questions etc answered by other but thanks for interesting info, Mondial is an old make name I know so interesting to hear it still used. In late 90's Hondas CG which we had here was actually made in Turkey, I wonder if this was the same factory even though it seems strange if they were making them with another name on as well.
In the end all comes back to the beginning
621andy
PostPosted: 08:23 - 10 Jun 2010    Post subject: Reply with quote
Here's their website; https://www.mondialmotorcycle.com/
You may recognise some other models too! There's also a brief history of the company soemwhere on the site.
I briefly had use of one of these;
[img]https://i250.photobucket.com/albums/gg244/621andy/DSCN8646a.jpg
also a Mondial product, but previous pilots here have ramped it so much that it can barely pull itself along, let alone someone my size Laughing
Thanks for the info everyone. I'll have a play later. The new exhaust was partly to try and cure the backfiring and the seal is very good, so I suspect the problem is mixture or the mysterious 'air cut off valve' Wink
As to racks, you'd probably pay about 10€ for one here! I've got a top box on mine now that I paid 20€ for.
Oh and yes, they're 12 volt.[/img]
The last post was made 16 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.95 - MySQL Queries: 13 - Page Size: 89.25 Kb
