| Neepling |
 Neepling Nitrous Nuisance
| imanupstart |
 imanupstart Traffic Copper
 Posted: 18:41 - 10 Jun 2010 Post subject: |
Very underrated bikes, my dads got one and it's a pretty nippy thing. Comfortable to boot. Fuck ugly though  |
| c_dug |
 c_dug Super Spammer
 Posted: 18:47 - 10 Jun 2010 Post subject: |
I just got one, very very happy with it, ridiculously economical for a 100bhp 600 too, can get over 60mpg if I try hard
Seems to be some really good ones about too
c_dug ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| SlimRick |
 SlimRick World Chat Champion
| SlimRick |
| c_dug |
 c_dug Super Spammer
| Hetzer |
 Hetzer Super Spammer
| SlimRick |
 Posted: 19:03 - 10 Jun 2010 Post subject: |
At least they took it out after 20 minutes - looks like they left you in for the full cycle  |
| imanupstart |
| Seb |
 Seb World Chat Champion
 Posted: 19:33 - 10 Jun 2010 Post subject: |
Bar a couple of minor caveats to keep an eye out for (Potentially weak second gear, exhaust midsection made of cheese, over complex fairing inners that have a habit of cracking) they are utterly dependable bikes, if anything mine felt a little bland simply because it didn't have any quirks or flaws. Plenty quick though  ____________________ 2010 Triumph 1050 Sprint ST |
| iooi |
 iooi Super Spammer
 Posted: 19:36 - 10 Jun 2010 Post subject: |
Owners Forum
Biggest know problem is I think 2nd gear jumping out... ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| johnsmith222 |
 johnsmith222 World Chat Champion
| c_dug |
 c_dug Super Spammer
| johnsmith222 |
| Omega |
 Omega Crazy Courier
| johnsmith222 |
| c_dug |
 c_dug Super Spammer
| SlimRick |
| johnsmith222 |
| Seb |
 Posted: 21:41 - 10 Jun 2010 Post subject: |
We have one (and most of another broken for spares).
2nd gear is a known problem. The dogs wear on the gears and need to be replaced to fix the problem. The box is fairly clunky when thrashed and suspect that thrashing from 1st through to 2nd results in the harsh smash of the gears into each other damaging the dogs.
Taking the fairing off is a pain, and replacing the speedo cable without taking off the fairing is even more of a pain. Same for changing the headlight bulb.
It is difficult to get the forks out with the fairing / air intakes in place (bolts on the lower yoke are allen key headed, and there is barely enough clearance to get an allen key into them). You need a very large hex key to get the front wheel spindle out.
Adjusting the shock is a pain as you pretty much have to take it off to do it. Getting the shock out isn't that easy either just because of the clearance to get at the bolts.
The one we have handled horribly when we first got it. Reset all the adjustments and it made no difference. Eventually found that the problem was that someone had put too heavy fork oil in it (stock is 10W on the later ones and 20W on the early ones without damping adjustment on the forks). With 10W oil back in it handles OK.
It is really good on petrol. Keep cruising speed to 80mph and it is managing just short of 60mpg. Sitting at 90 noticeably increases consumption. With a decent size tank it means I can manage about 190 miles on a tank full (getting me to and from work on a single tank).
I find the seat to not be that comfortable. Not sure whether it is the seat itself or the pegs being high and the seat fairly low. Starts to get uncomfortable after and hour and a half.
Frame sides are easily damaged if you drop it.
Brake disks warp easily. Probably mainly because the front calipers seize up really easily. As mentioned the rear caliper seizes fairly quickly, but at least it is a doddle to strip and rebuild.
If you need to replace the front wheel bearings then watch out as on one of them there is nothing to stop the bearing going all the way into the wheel!
The last post was made 16 years, 85 days ago. Instead of replying here, would creating a new thread be more useful? |
