| calyx |
 calyx World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 14:04 - 11 Jun 2010 Post subject: |
Powerband store? ____________________ a.k.a 'Geri'
| Pie-Roe |
 Pie-Roe World Chat Champion
 Posted: 15:30 - 11 Jun 2010 Post subject: |
They do exist, I had a semi automatic clutch on my drz.
Try searching for a centrifugal clutch kit for whatever bike, but I'm pretty sure they are only available for certain singles as a supermoto addon. They are very pricey too, mine came with the bike and with a receipt of £387.
Pyro ____________________ Previous: GSF600, FZR600 x2, ZXR750, XT600 Tenere, CB125, CZ125, ETZ 250, ER5, CCM R30, DRZ400, RF600x4, RF900x2, GS500, VTR1000F, 640 SMC, CB250 NIGHTHAWK, GT550x3, GPX750 TE610, CB500, X11x2, SV650, ZING 125, TL1000R,CB250 Superdream, CBR1100XX |
| G |
 G The Voice of Reason
 Posted: 15:44 - 11 Jun 2010 Post subject: Re: Semi automatic clutch plates |
As above... with the left handed screw drivers .
It depends entirely on the system – for instance on a c90 I believe you can add in a clutch cable and the plates are exactly the same as models with a clutch.
Quite a lot of the auto clutch systems these days use the standard plates now I think, others it will be specific to the system. |
| calyx |
| G |
| SamJL |
 SamJL Nearly there...
 Posted: 17:55 - 11 Jun 2010 Post subject: |
A friend I know used to race with a guy who was paralysed in 1 arm, he had a hydraulic clutch made, that was button press and mounted it to the other side of the bike.
Apparently the guy was bloody quick aswell! ____________________ 2009 CBR1000RR
2004 KTM 200SX
2004 KTM 65SX  |
| Pete. |
 Pete. Super Spammer
| G |
 Posted: 20:38 - 11 Jun 2010 Post subject: |
Why do you need a lever for the road - if it's gear changes, presumably could add a quick shifter etc.
The dirt bike version often lose the clutch lever and they do fine - though not sure how that works actually. |
| Pete. |
 Pete. Super Spammer
 Posted: 21:33 - 11 Jun 2010 Post subject: |
I guess you could modify one for a lower take-up rpm but you can't even ride a slider-equipped drag bike back to the pits. Some have a lever to comply with rules but it does little more than make the bike move when you hold it in. ____________________ a.k.a 'Geri'
| G |
| Pie-Roe |
 Posted: 09:57 - 12 Jun 2010 Post subject: |
On my DRZ the clutch was only used for pulling it in and making a lot of noise.
You just gave it a handful and it went, kicked up and down the box as much as you like and the rear would never lock up, it wouldn't stall at low speeds in high gears.
Was quite fun, but got boring in the end. Plus it had a slightly laggy effect so in first gear you'd give it a handful then it would move slowly ish and then chuck the front up, nearly flipped it a few times pulling out from junctions.
The last post was made 16 years, 84 days ago. Instead of replying here, would creating a new thread be more useful? |
