GSXR 400 Airbox
AcePepto
PostPosted: 13:58 - 12 Jun 2010    Post subject: GSXR 400 Airbox Reply with quote
I recently bought an '89 GSXR 400 and when i got it home and took a decent look at it, i noticed that the person who had it before me had cut a slot in the side of the airbox so they didnt have to disconnect the throttle cable before removing the airbox, and that the plastic seals between the carb and the airbox dont sit in the airbox tightly.
Is there any harm in riding without the airbox on it, or is there some individual filters i can get for it instead??
PostPosted: 17:42 - 12 Jun 2010    Post subject: Reply with quote
YOu need filtration or you'll pull in dust and dirt which will grind the engine internals to bits. Best bet is to find a replacement airbox. Ask about on 400greybike
temeluchus
PostPosted: 18:30 - 12 Jun 2010    Post subject: Reply with quote
Airbox is your best bet. You could get individual filters, but this WILL need messing with jetting.
You could repair the box with sealant (black RTV silicone or similar).
AcePepto
PostPosted: 18:47 - 12 Jun 2010    Post subject: Reply with quote
Thanks guys i'll check them out, its not running right anyway so im gonna have a look at the jets etc.
Also i've noticed that there is a knocking coming from somewhere in the engine when i drive faster than 45mph, the front sprocket is slightly loose because it isn't held on in the same way modern ones are, so i think it's either that, or the cam chain. Any ideas?
PostPosted: 19:08 - 12 Jun 2010    Post subject: Reply with quote
Cam chains don't knock. What's up with the front sprocket? Many aren't held solidly on the shaft but they don't knock usually either.
AcePepto
PostPosted: 19:51 - 12 Jun 2010    Post subject: Reply with quote
The sprocket is only held in with what looks like a circlip, there isn't a nut and washer on it, and theres a bit of play on it side to side. There is a knocking from somewhere that's quite fast, but it only knocks when im doing over 45mph which is quite odd. It's kind of hard to describe properly without actually hearing it. Sad
Also, i can't find online anywhere what the jet sizes should be on the carbs, because i don't think its running right, and i also can't find how far out the fuel/air mix tap should be turned from stop. Any ideas?
V2
PostPosted: 19:56 - 12 Jun 2010    Post subject: Reply with quote
If its not running right before messing with the jetting and such forth read this, could save yourself a lot of bother! https://tonysleep.co.uk/gsxr400carbs
AcePepto
PostPosted: 20:02 - 12 Jun 2010    Post subject: Reply with quote
Thanks superretard, i'll read over that and see if it helps sort it out Very Happy
boundy
PostPosted: 22:42 - 12 Jun 2010    Post subject: Reply with quote
Before messing about with the carbs you might want to sort the airbox out, this might be the cause of the running problems
AcePepto
PostPosted: 15:26 - 21 Jun 2010    Post subject: Reply with quote
I've bought a new set of carbs from eBay, and i'm going to see if I can get them to run right, because I think the seller said that they had already been set. But if that doesn't work I know someone who has a dyno and I think he can balance carbs aswell, so I can always get him to take a look.
Thanks for the help everyone Very Happy
The last post was made 16 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.13 - MySQL Queries: 13 - Page Size: 63.16 Kb
