| AcePepto |
 AcePepto L Plate Warrior
 Posted: 17:42 - 12 Jun 2010 Post subject: |
YOu need filtration or you'll pull in dust and dirt which will grind the engine internals to bits. Best bet is to find a replacement airbox. Ask about on 400greybike ____________________ a.k.a 'Geri'
| temeluchus |
| AcePepto |
 Posted: 19:08 - 12 Jun 2010 Post subject: |
Cam chains don't knock. What's up with the front sprocket? Many aren't held solidly on the shaft but they don't knock usually either. ____________________ a.k.a 'Geri'
| AcePepto |
 Posted: 19:51 - 12 Jun 2010 Post subject: |
The sprocket is only held in with what looks like a circlip, there isn't a nut and washer on it, and theres a bit of play on it side to side. There is a knocking from somewhere that's quite fast, but it only knocks when im doing over 45mph which is quite odd. It's kind of hard to describe properly without actually hearing it.
Also, i can't find online anywhere what the jet sizes should be on the carbs, because i don't think its running right, and i also can't find how far out the fuel/air mix tap should be turned from stop. Any ideas?
| V2 |
 V2 Nearly there...
 Posted: 19:56 - 12 Jun 2010 Post subject: |
If its not running right before messing with the jetting and such forth read this, could save yourself a lot of bother! https://tonysleep.co.uk/gsxr400carbs |
| AcePepto |
 Posted: 20:02 - 12 Jun 2010 Post subject: |
Thanks superretard, i'll read over that and see if it helps sort it out  |
| boundy |
 boundy Nearly there...
| AcePepto |
 Posted: 15:26 - 21 Jun 2010 Post subject: |
I've bought a new set of carbs from eBay, and i'm going to see if I can get them to run right, because I think the seller said that they had already been set. But if that doesn't work I know someone who has a dyno and I think he can balance carbs aswell, so I can always get him to take a look.
Thanks for the help everyone  |
The last post was made 16 years, 23 days ago. Instead of replying here, would creating a new thread be more useful? |
