Thundercat 'Blue Spot' caliper rebuild
jay_666
PostPosted: 13:35 - 13 Jun 2010    Post subject: Thundercat 'Blue Spot' caliper rebuild Reply with quote
Having trouble removing the pistons from my thundercat's brake calipers on the front. The calipers do not split apart and i cant see how to remove the pistons as they oppose eachother Confused One of them is also seized in place and wont budge.
My plan is to strip the calipers, clean up the pistons and fit new seals.
Any held would be greatly appreciated, as im pretty stuck at the moment.
PostPosted: 13:46 - 13 Jun 2010    Post subject: Reply with quote
Never touched them but don't the blue bits un-screw? As for the stuck piston, pump it out with the brake lever and clean it.
PostPosted: 13:52 - 13 Jun 2010    Post subject: Reply with quote
This.
I think you need a tool from Yamaha/ISR though. Don't think you can get a big enough torx bit at a normal shop.
jay_666
PostPosted: 14:18 - 13 Jun 2010    Post subject: Reply with quote
this? --> https://www.billetbikebits.com/shop/index.php?main_page=product_info&products_id=82
Ive been told the blue spots screw inwards though?as in towards where the rotor would be... Confused
druidsam
PostPosted: 15:03 - 13 Jun 2010    Post subject: Reply with quote
having recently rebuilt my thundercat calipers, the best advise i can give you is this, remove the calliper from the fork leg and take the brake pads out , put a piece of wood in the caliper where the pistons are and slowly pump the pistons out using the brake lever, when the pistons are ALL touching the wood replace it with a thinner piece and pump the pistons out some more.
doing it this way ensures that if one or more pistons are sticking you will still be able to get them out relatively easy
when replacing the seals make sure the grooves are spotless, the slightest bit of crud in these stops the new seal from seeting properly and makes it very difficult to refit the piston
trust me! I'm a druid
https://www.bikerforum.co.uk/
jay_666
PostPosted: 15:24 - 13 Jun 2010    Post subject: Reply with quote
Thing is, i dont understand how to remove all of the pistons. They come out together, and end up face to face as they oppose each other, leaving no room for removal. and one one is out, there is no pressure in the system to push the rest out.
el_oso
PostPosted: 15:30 - 13 Jun 2010    Post subject: Reply with quote
you may need to top up the brake fluid level. check there is fluid in the reservoir.
Duke 390
Car: Jeep Wrangler 4.0L
jay_666
PostPosted: 15:31 - 13 Jun 2010    Post subject: Reply with quote
fluid levels are fine
druidsam
PostPosted: 15:37 - 13 Jun 2010    Post subject: Reply with quote
if the pistons are touching they are nearly out, push one back in a little bit and clamp it so it cant move then pump out the opposite piston,
once the pressure in the braking system is lost, is just a matter of wiggling the pistons out , i removed mine with a cloth and pair of vice grips
el_oso
PostPosted: 15:41 - 13 Jun 2010    Post subject: Reply with quote
once you have lost all pressure then you should be able to pull the pistons out by wiggling them around
Duke 390
jay_666
PostPosted: 16:07 - 13 Jun 2010    Post subject: Reply with quote
I've read around and people refer to using 'clamps' to hold the pistons. Space is so limited i dont see how you can get a g-clamp in the caliper at all.
Also, the pistons are really stiff to press back into the caliper. some of the dust seals are starting to expose themselves and im worried if i push one piston out using the brake lever, i wont be able to get the others out due to them being so stiff.
druidsam
PostPosted: 16:40 - 13 Jun 2010    Post subject: Reply with quote
this was the same problem that i faced, but you just have to grit your teeth and release the pressure, then its a case of push one piston in enough to allow the opposite piston to come out
i gripped the top of the piston with vice grips( use a cloth so you dont mark the pistons) and used a twisting motion to get them out
if its any consolation refitting is a lot easier than removal Wink
then you just have the fun of bleeding the brakes Crying or Very sad
but its worth the effort when the job is done Thumbs Up
jay_666
PostPosted: 20:35 - 13 Jun 2010    Post subject: Reply with quote
by 'vice grips' do you mean mole grips?
jay_666
PostPosted: 22:20 - 13 Jun 2010    Post subject: Reply with quote
Yeah, thats why i ask. I dont really want to be touching those pistons with anything if i can help it...
Noxious89123
PostPosted: 23:10 - 13 Jun 2010    Post subject: Reply with quote
This.
https://www.machinemart.co.uk/shop/product/details/cht268-disc-brake-piston-spreader/path/automotive-tools
The last post was made 15 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 96.65 Kb
