| jay_666 |
 jay_666 World Chat Champion
 Posted: 13:35 - 13 Jun 2010 Post subject: Thundercat 'Blue Spot' caliper rebuild |
Having trouble removing the pistons from my thundercat's brake calipers on the front. The calipers do not split apart and i cant see how to remove the pistons as they oppose eachother One of them is also seized in place and wont budge.
My plan is to strip the calipers, clean up the pistons and fit new seals.
Any held would be greatly appreciated, as im pretty stuck at the moment. ____________________ CBT - Done | Theory - Passed | Test - 4th Oct [PASSED!]
https://www.bikepics.com/members/jay666/ |
 Posted: 13:46 - 13 Jun 2010 Post subject: |
Never touched them but don't the blue bits un-screw? As for the stuck piston, pump it out with the brake lever and clean it. ____________________ a.k.a 'Geri'
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| jay_666 |
| druidsam |
 druidsam Crazy Courier
 Posted: 15:03 - 13 Jun 2010 Post subject: |
having recently rebuilt my thundercat calipers, the best advise i can give you is this, remove the calliper from the fork leg and take the brake pads out , put a piece of wood in the caliper where the pistons are and slowly pump the pistons out using the brake lever, when the pistons are ALL touching the wood replace it with a thinner piece and pump the pistons out some more.
doing it this way ensures that if one or more pistons are sticking you will still be able to get them out relatively easy
when replacing the seals make sure the grooves are spotless, the slightest bit of crud in these stops the new seal from seeting properly and makes it very difficult to refit the piston ____________________ trust me! I'm a druid
https://www.bikerforum.co.uk/ |
| jay_666 |
 Posted: 15:24 - 13 Jun 2010 Post subject: |
Thing is, i dont understand how to remove all of the pistons. They come out together, and end up face to face as they oppose each other, leaving no room for removal. and one one is out, there is no pressure in the system to push the rest out. ____________________ CBT - Done | Theory - Passed | Test - 4th Oct [PASSED!]
| el_oso |
 el_oso World Chat Champion
| jay_666 |
| druidsam |
| el_oso |
| jay_666 |
 Posted: 16:07 - 13 Jun 2010 Post subject: |
I've read around and people refer to using 'clamps' to hold the pistons. Space is so limited i dont see how you can get a g-clamp in the caliper at all.
Also, the pistons are really stiff to press back into the caliper. some of the dust seals are starting to expose themselves and im worried if i push one piston out using the brake lever, i wont be able to get the others out due to them being so stiff. ____________________ CBT - Done | Theory - Passed | Test - 4th Oct [PASSED!]
| druidsam |
 Posted: 16:40 - 13 Jun 2010 Post subject: |
| jay_666 |
| Vincent |
 Vincent Banned
| jay_666 |
 Posted: 22:20 - 13 Jun 2010 Post subject: |
Yeah, thats why i ask. I dont really want to be touching those pistons with anything if i can help it... ____________________ CBT - Done | Theory - Passed | Test - 4th Oct [PASSED!]
| Vincent |
 Vincent Banned
| Noxious89123 |
The last post was made 15 years, 234 days ago. Instead of replying here, would creating a new thread be more useful? |
