bsa b25 starfire blowin fuse 1970
abiteachuck
PostPosted: 22:25 - 16 Jun 2010    Post subject: bsa b25 starfire blowin fuse 1970 Reply with quote
Hi, everybody ive just joined, so thanks for havin me.
i just bought this bike 95% finished, but i cant seem to sort out the fault.
the bike is + earth, whats happening is when you try to start it it blows the fuse the has burnt out a set of points.the reason must be the feed is perminent live so every time the points close it creates a dead short, any help will be greatful,hope i have made it clear.
thanks keith.
They dont make um like this any more.
Paddy Blake
PostPosted: 22:33 - 16 Jun 2010    Post subject: Reply with quote
I am not sure but I think there should be a wire from the points to a condenser then from there to the HT coil.
Is there a condenser in where the points are. Question
abiteachuck
PostPosted: 22:46 - 16 Jun 2010    Post subject: Reply with quote
thanks ya there is a condenser and its wired to the same wire that feeds the points it comes from the + side of the coil
Paddy Blake
PostPosted: 22:53 - 16 Jun 2010    Post subject: Reply with quote
That sounds wrong.
I will have a quick look for a wiring diagram for close to that.
Have a look here to see if there is something with points that may help you.
https://www.bikechatforums.com/viewtopic.php?p=2322761#2322761
I have to go.
PostPosted: 23:24 - 16 Jun 2010    Post subject: Reply with quote
Scorched/burned points are a symptom of a duff condenser.
It would have to be totally mangled to give a dead short though. Even if it was, you should still have enough resistance in the primary windings to prevent a fuse popping. The coil might get pretty hot though.
I suspect you have a short circuit™* in the wiring leading from the points to the ignition coil or an internal short in the primary windings of the ignition coil.
A duff/disconnected zennor could also lead to fuses blowing (due to excess voltage) but only when the engine is running.
I did a wee sketch of an ultra basic points iginition system (not included ignition switch and fuse).
* "Short circuit" is a trade mark of the LUCAS Electrical Company. Patent No: 1562329A6
Odie
PostPosted: 01:50 - 17 Jun 2010    Post subject: Reply with quote
Problem is with your understanding of the markings on the coil.
The + is not positive but power feed in (- in + earth bikes) and the - on the coil goes to the points.
+ = power in, - = low tension
abiteachuck
PostPosted: 21:46 - 17 Jun 2010    Post subject: Reply with quote
thanks for your reply but it dose`nt work like that the - is for the feed and the + go`s to the points.
thanks anyway keith.
abiteachuck
PostPosted: 21:54 - 17 Jun 2010    Post subject: Reply with quote
thanks for the help your drawing is spot on,the fault was there was a live feed to both sides of the coil, so thats why the points were live even when the points were closed, took the wire off the + put it on the neg, the the points wire on the + and it started 3rd kick.
thanks again keith.
The last post was made 15 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 56.33 Kb
