Bike is not sounding at all good (video attached)
Whosthedaddy
PostPosted: 21:29 - 18 Jun 2010    Post subject: Bike is not sounding at all good (video attached) Reply with quote
Riding at a healthy pace on the way home, had a thought that the wind noise in my helmet was affecting the music, pulled over and nope, a horrid knocking noise.
https://www.youtube.com/watch?v=eJ97WXXMfe4
I then spent the remaining 17 odd miles almost coasting home fearing it would stutter and cut out.
It did cross my mind that I had dropped a cylinder as sounded like a big single but no, both exhausts are working fine and feeling powerful when the throttle is blipped.
I haven't noticed anything wrong or to worry about, a real bolt out of the blue!
Question
27cows
PostPosted: 21:31 - 18 Jun 2010    Post subject: Reply with quote
Sounds unpleasantly like it could be a big end.
Whosthedaddy
PostPosted: 21:43 - 18 Jun 2010    Post subject: Reply with quote
Still pulled to some extent although didn't really want to try it too much. The idea of knackering the engine at xmph on a NSL road was a little worrying.
PostPosted: 21:54 - 18 Jun 2010    Post subject: Reply with quote
That sounds awful.
Cam chain tensioner become loose, maybe? I have no idea what I'm talking about though.
cb1rocket
PostPosted: 21:56 - 18 Jun 2010    Post subject: Reply with quote
it could be anything, but first check the basics, could be cam chain tensioner, but as the knocking is so consistant, it could well be the big end.
Looks like an engine out job to inspect unfortunatly.
Could just be better off buying a new engine perhaps from a breaker? or get a smashed up donar off ebay
Whosthedaddy
PostPosted: 22:07 - 18 Jun 2010    Post subject: Reply with quote
Not rare but not popular due to only a 4 year production so sourcing large parts could be a problem.
Bru
PostPosted: 22:54 - 18 Jun 2010    Post subject: Reply with quote
Sounds too deep in tone to be chain. In fact, sounds almost exactly like my engine (also a twin), when one of the big ends failed. Did your temp rise (on the bike)?
Best bet - drain the oil into a shallow pan, and then pour it slowly out into another container. If you spot glittery flakes at the bottom of the first container, then you know it's a bearing.
Avoid riding the bike, as you could still get away with just bearings, rather than losing the crank.
PostPosted: 23:01 - 18 Jun 2010    Post subject: Reply with quote
Use a screwdriver/bit of broom handle pressed against your ear and strategic parts of the engine as a sounding rod to localise where the noise is coming from. You'll be surprised at what you can hear.
Two, left of field suggestions.
1) Loose spark plug.
2) Balancer chain (I assume it must have a balancer in there given the firing order).
mr.kris
PostPosted: 17:40 - 19 Jun 2010    Post subject: Reply with quote
TRX850s are known for crank problems id say thats what it sounds like sorry! Xxx
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
Whosthedaddy
PostPosted: 22:24 - 19 Jun 2010    Post subject: Reply with quote
Thanks guys.
Easiest thing would be to change the oil tomorrow and look for any debris as will be making sure that the plugs are snug.
I've heard about the screwdriver to the ear listening for the knocking but to be honest it'll mean nothing to me other than top or bottom, front or back.
A loose crank actually knackered the engine in my old Impreza, I believe it to have been due to Halfords not tightening a pulley properly after they changed the cambelt.
What could cause a crank to go? No work has been done on it or is it just a design or V twin problem?
PostPosted: 22:32 - 19 Jun 2010    Post subject: Reply with quote
Drop the oil - if you have golden/bronze coloured flakes of metal fall out or what looks like silver paint floating on the oil then your ends have had it - which will mean the crank is shot and probably the rod too. If it's really bad you might even have kissed the valves.
WD Forte
PostPosted: 23:44 - 19 Jun 2010    Post subject: Reply with quote
My guess is not big ends but main bearings
ends usually clatter when you rev up while this noise is
constant at tick over
OR
generator rotor come adrift maybe?
Just guesses of course, as said you need to open her up and
have a look
Phoenix
Twisted Firestarter
PostPosted: 02:05 - 20 Jun 2010    Post subject: Reply with quote
Doesn't sound good, sounds like my first Fireblade years ago before the engine ate itself, it'd had a crank regrind previously and always had a tapping noise but very quickly over the course of a day it got worse and worse until it sounded like a tractor with the exhaust manifold off and then just died completely.
Best bet is as stinkwheel says though, drain oil and check balancer chain and camchain, if they're all ok then the engine has to come apart anyway so you've just made a start.
instigator
PostPosted: 02:22 - 20 Jun 2010    Post subject: Reply with quote
G knows about the TRX's, I'd PM him for a response.
Its one of the reasons why I never got a TRX - I think they were known for having shit top ends. Quite what goes wrong with them, I don't know...something about their valves....well that was fucking useful, eh? Laughing
hmmmnz
PostPosted: 02:55 - 20 Jun 2010    Post subject: Reply with quote
this is sounding very much like a cagiva ive been working on,
the starter clutch bolts attached to the flywheel/generator have loosened up, and are knocking on the engine block as they spin past.
what i would do is
1. check the timing chain, tensionor, and timing,
2, dump the oil, pull the left cover, and see if there is any play in the crank.
3, pull off the flywheel, and check the balance shaft chain/gear and see if thats sweet,
check the starter clutch bolts, and preen them if need be,
if all of that looks good,
then i would drop the engine, and dissasemble the top end , and check the piston, valves and bore,
if they all look good, then i would pull the barrel, and see if you have any play in the piston and on the conrod,
if you have got that far and still not found anything.... well Very Happy
i'd be looking for a new engine
good luck, shouldnt be too hard to find the cause,,,.... fixing it may be an arse though
the humans are dead
I kick arse for the lord
MaybeGuy
PostPosted: 08:46 - 20 Jun 2010    Post subject: Reply with quote
could be one of the exhausts blowing at the head.
observe
https://www.youtube.com/watch?v=JinH0XtN0mw
Whosthedaddy
PostPosted: 14:08 - 20 Jun 2010    Post subject: Reply with quote
Yep.
Small filings, odd bit if 'paint' and a fair few larger chuncks of bronze coloured shards.
Feck!
hmmmnz
PostPosted: 14:15 - 20 Jun 2010    Post subject: Reply with quote
man that sucks,
tedium engine
the humans are dead
The last post was made 16 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 102.51 Kb
