| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 21:29 - 18 Jun 2010 Post subject: Bike is not sounding at all good (video attached) |
Riding at a healthy pace on the way home, had a thought that the wind noise in my helmet was affecting the music, pulled over and nope, a horrid knocking noise.
https://www.youtube.com/watch?v=eJ97WXXMfe4
I then spent the remaining 17 odd miles almost coasting home fearing it would stutter and cut out.
It did cross my mind that I had dropped a cylinder as sounded like a big single but no, both exhausts are working fine and feeling powerful when the throttle is blipped.
I haven't noticed anything wrong or to worry about, a real bolt out of the blue!
 ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| 27cows |
 27cows World Chat Champion
| Whosthedaddy |
| ms51ves3 |
 ms51ves3 Super Spammer
| cb1rocket |
 cb1rocket World Chat Champion
| Whosthedaddy |
| Bru |
 Bru Trackday Trickster
| stinkwheel |
 Posted: 23:01 - 18 Jun 2010 Post subject: |
Use a screwdriver/bit of broom handle pressed against your ear and strategic parts of the engine as a sounding rod to localise where the noise is coming from. You'll be surprised at what you can hear.
Two, left of field suggestions.
1) Loose spark plug.
2) Balancer chain (I assume it must have a balancer in there given the firing order). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| mr.kris |
 mr.kris Traffic Copper
| Whosthedaddy |
 Posted: 22:24 - 19 Jun 2010 Post subject: |
Thanks guys.
Easiest thing would be to change the oil tomorrow and look for any debris as will be making sure that the plugs are snug.
I've heard about the screwdriver to the ear listening for the knocking but to be honest it'll mean nothing to me other than top or bottom, front or back.
A loose crank actually knackered the engine in my old Impreza, I believe it to have been due to Halfords not tightening a pulley properly after they changed the cambelt.
What could cause a crank to go? No work has been done on it or is it just a design or V twin problem? ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| Pete. |
 Pete. Super Spammer
 Posted: 22:32 - 19 Jun 2010 Post subject: |
Drop the oil - if you have golden/bronze coloured flakes of metal fall out or what looks like silver paint floating on the oil then your ends have had it - which will mean the crank is shot and probably the rod too. If it's really bad you might even have kissed the valves. ____________________ a.k.a 'Geri'
| WD Forte |
 WD Forte World Chat Champion
| Phoenix |
 Phoenix Twisted Firestarter
| instigator |
 instigator Super Spammer
 Posted: 02:22 - 20 Jun 2010 Post subject: |
G knows about the TRX's, I'd PM him for a response.
Its one of the reasons why I never got a TRX - I think they were known for having shit top ends. Quite what goes wrong with them, I don't know...something about their valves....well that was fucking useful, eh?  |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 02:55 - 20 Jun 2010 Post subject: |
this is sounding very much like a cagiva ive been working on,
the starter clutch bolts attached to the flywheel/generator have loosened up, and are knocking on the engine block as they spin past.
what i would do is
1. check the timing chain, tensionor, and timing,
2, dump the oil, pull the left cover, and see if there is any play in the crank.
3, pull off the flywheel, and check the balance shaft chain/gear and see if thats sweet,
check the starter clutch bolts, and preen them if need be,
if all of that looks good,
then i would drop the engine, and dissasemble the top end , and check the piston, valves and bore,
if they all look good, then i would pull the barrel, and see if you have any play in the piston and on the conrod,
if you have got that far and still not found anything.... well
i'd be looking for a new engine
good luck, shouldnt be too hard to find the cause,,,.... fixing it may be an arse though ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 08:46 - 20 Jun 2010 Post subject: |
could be one of the exhausts blowing at the head.
observe
https://www.youtube.com/watch?v=JinH0XtN0mw ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Whosthedaddy |
| hmmmnz |
 Posted: 14:15 - 20 Jun 2010 Post subject: |
The last post was made 16 years, 15 days ago. Instead of replying here, would creating a new thread be more useful? |
