| paulcdb |
 paulcdb Scooby Slapper
 Posted: 01:08 - 20 Jun 2010 Post subject: CBR 600 forks will '90 fit '93? |
as title just curious if anyone knows if 1990 forks will fit a 1993 ?
mine are knackered, leaking, seized bolts and so far been a royal pita and need it mot'd quick. few on ebay but not sure what the difference is between models. ____________________ Excersise is rubbish!
If your healthy you don't need it... if your sick you shouldn't do it. |
| supZ |
 supZ World Chat Champion
| hondapartsman |
 hondapartsman Renault 5 Driver
 Posted: 08:11 - 20 Jun 2010 Post subject: |
Definitely different, for uk check this site https://www.hondaoriginalparts.com/ does not show Honda numbers as Honda do not allow it but the pfkl numbers will match. Don't know what supZ means by F1 and F2 though, it doesn't work that way and can confusion using those designations as those designations were used by Honda later on different models. F1 for 2001 F2 for 2002 and for the US other things as well.
1990 is FL model, L being model year 1990, 1993 is P model. Simple enough.
The forks are basically bigger on the 1993, I forget the sizes well Honda seldom show those in parts lists so no, would not even fit your yokes and although there's an outside chance of you have the whole thing yokes included you could make them fit then you'd likely need a wheel etc as well and all would be damned hard.
Sorry, no easy fix there. Earlier forks might be okay if you could find some, as I recall up to the FL they were pretty much the same but the FM in 1991 was a major redesign. That's where people started all this crap about F1's and 2's etc. ____________________ In the end all comes back to the beginning |
| cb1rocket |
 cb1rocket World Chat Champion
| paulcdb |
 Posted: 00:32 - 21 Jun 2010 Post subject: |
thanks for the replies.
i got hold of a haynes manual and it lists FM/N as 443.2mm and FP/R as 429.3mm and not sure what FL is so can't tell if they will and nothing on ebay, lol
Anyone happen to have forks off an FM/N for sale?  ____________________ Excersise is rubbish!
| Kickstart |
 Kickstart The Oracle
The last post was made 16 years, 24 days ago. Instead of replying here, would creating a new thread be more useful? |
