Help a PHP/SQL virgin.
Faldo
PostPosted: 16:15 - 22 Jun 2010    Post subject: Help a PHP/SQL virgin. Reply with quote
Right, total n00b at this, so if anything I say doesn't make sense feel free to correct me, preferably without too much pisstaking.
I want to make a form, submit the data to an SQL database then send the user an email confirming the data that has been submitted.
I then want to be able to recreate that data on another webpage.
So, for example, I'll have text fields for name, location, favourite biscuit etc, then a dropdown list for country, maybe a check box for T&Cs confirmation. I want to send that info to the database (I can make MySQL database & tables with PHPmyAdmin right?). I then want another page to access the data and show it.
Can anyone point me to any Opensource scripts that I can have a play with?
Cheers Thumbs Up .
PostPosted: 16:29 - 22 Jun 2010    Post subject: Reply with quote
Tizag has good tutorials for PHP and MySQL :-
https://www.tizag.com/phpT/
https://www.tizag.com/mysqlTutorial/
Faldo
PostPosted: 16:31 - 22 Jun 2010    Post subject: Reply with quote
Cheers Shag, I'll take a look at that later.
PostPosted: 16:47 - 22 Jun 2010    Post subject: Reply with quote
That should be very easy to do.
You can use phpmyadmin to create databases.
You are best off using a basic development setup on your own PC to write it and then putting it to a real server when it is ready. I use Wampserver but there are others which others prefer.
Watch out for SQL injection. Basically make sure you use mysql_real_escape_string.
Personally I would suggest finding a basic php script for anything and understanding how that works before moving on to try and write something.
But essentially you would want something like the following. Note that I haven't test run this in the slightest, but hopefully it will give you the right idea.
Code:
<?php
// Just got the countries in an array here, although realistically you would have them in a database instead.
$CountryArray = array(1 => 'Britain', 2 => 'Argentina', 5 => 'Brazil');
$ErrorMessage = '';
if ($_REQUEST['Submit'])
   // Submit button hit
   $username = $_REQUEST['username'];
   $userlocation = $_REQUEST['userlocation'];
   $userbiscuit = $_REQUEST['userbiscuit'];
   $usercountry = ((is_numeric($_REQUEST['usercountry'])) ? intval($_REQUEST['usercountry']) : 0); // If country isn't a valid interger then just use 0 instead, should be the id of it from the array at the top (or the id from the database)
   $Error = false;
   //Validate Input, set $Error = true if errors found
   if($Error)
      $ErrorMessage = 'Fix them errors and try again';
   else
      $dbms = 'mysql';
      $dbhost = 'yourhostname';
      $dbname = 'yourdatabasename';
      $dbuser = 'userid';
      $dbpasswd = 'password';
      // Make the database connection.
      $Conn = mysql_connect($dbhost,$dbuser,$dbpasswd);
      mysql_select_db($dbname,$Conn) or die(mysql_error());
      $sql = "INSERT INTO sometable (Id, Username, UserLocation, UserFavBiscuit, UserCountry) VALUES(NULL, '".mysql_real_escape_string($username)."', '".mysql_real_escape_string($userlocation)."', '".mysql_real_escape_string($userbiscuit)."', $usercountry') ";
      $void = mysql_query($sql) or die(mysql_error());
      // Send email
      $subject = 'A note for Faldo';
      $message = "The following details were entered on a form .\n";
      $message .= "A line with some details $username   $userlocation   $userbiscuit.\n";
      $message = wordwrap($message, 70);
      $headers = 'From: The Web Page' . "\r\n" .
      $headers .= "X-Mailer: PHP/" . phpversion()."\n";
      $headers .= "Importance: High\n";
      mail($to, $subject, $message, $headers);
      // All went OK so redirect to another script.
      header('Location:AnotherScript.php');
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head>
<title>Faldo Test</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
</head>
<body>
   <form method="post" name="form1" target="_self">
      <input type='text' id='username' name='username' value='<?php echo $username ?>' /><br />
      <input type='text' id='userlocation' name='userlocation' value='<?php echo $userlocation ?>' /><br />
      <input type='text' id='userbiscuit' name='userbiscuit' value='<?php echo $userbiscuit ?>' /><br />
      <select name='usercountry' >
         <?php
         foreach($CountryArray AS $CountryId=>$CountryName)
            echo "<option value='$CountryId'".(($usercountry == $CountryId) ? "selected='selected'" : '' )." >$CountryName</option><br />";
      </select>
      <?php echo $ErrorMessage; ?><br />
   </form>
</body>
</html>
Faldo
PostPosted: 16:53 - 22 Jun 2010    Post subject: Reply with quote
Excellent Keith, a lot of that makes some sense to me. I'll have a play about with them tomorrow.
Thanks Thumbs Up .
The last post was made 16 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 50.55 Kb
