 Faldo World Chat Champion
 Posted: 16:15 - 22 Jun 2010 Post subject: Help a PHP/SQL virgin. |
Right, total n00b at this, so if anything I say doesn't make sense feel free to correct me, preferably without too much pisstaking.
I want to make a form, submit the data to an SQL database then send the user an email confirming the data that has been submitted.
I then want to be able to recreate that data on another webpage.
So, for example, I'll have text fields for name, location, favourite biscuit etc, then a dropdown list for country, maybe a check box for T&Cs confirmation. I want to send that info to the database (I can make MySQL database & tables with PHPmyAdmin right?). I then want another page to access the data and show it.
Can anyone point me to any Opensource scripts that I can have a play with?
Cheers . |
 The Shaggy D.A. Super Spammer
 Posted: 16:29 - 22 Jun 2010 Post subject: |
Tizag has good tutorials for PHP and MySQL :-
https://www.tizag.com/phpT/
https://www.tizag.com/mysqlTutorial/ ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
 Posted: 16:31 - 22 Jun 2010 Post subject: |
Cheers Shag, I'll take a look at that later. |
 Kickstart The Oracle
 Posted: 16:47 - 22 Jun 2010 Post subject: |
That should be very easy to do.
You can use phpmyadmin to create databases.
You are best off using a basic development setup on your own PC to write it and then putting it to a real server when it is ready. I use Wampserver but there are others which others prefer.
Watch out for SQL injection. Basically make sure you use mysql_real_escape_string.
Personally I would suggest finding a basic php script for anything and understanding how that works before moving on to try and write something.
But essentially you would want something like the following. Note that I haven't test run this in the slightest, but hopefully it will give you the right idea.
| Code: |
<?php
// Just got the countries in an array here, although realistically you would have them in a database instead.
$CountryArray = array(1 => 'Britain', 2 => 'Argentina', 5 => 'Brazil');
$ErrorMessage = '';
if ($_REQUEST['Submit'])
// Submit button hit
$username = $_REQUEST['username'];
$userlocation = $_REQUEST['userlocation'];
$userbiscuit = $_REQUEST['userbiscuit'];
$usercountry = ((is_numeric($_REQUEST['usercountry'])) ? intval($_REQUEST['usercountry']) : 0); // If country isn't a valid interger then just use 0 instead, should be the id of it from the array at the top (or the id from the database)
$Error = false;
//Validate Input, set $Error = true if errors found
if($Error)
$ErrorMessage = 'Fix them errors and try again';
else
$dbms = 'mysql';
$dbhost = 'yourhostname';
$dbname = 'yourdatabasename';
$dbuser = 'userid';
$dbpasswd = 'password';
// Make the database connection.
$Conn = mysql_connect($dbhost,$dbuser,$dbpasswd);
mysql_select_db($dbname,$Conn) or die(mysql_error());
$sql = "INSERT INTO sometable (Id, Username, UserLocation, UserFavBiscuit, UserCountry) VALUES(NULL, '".mysql_real_escape_string($username)."', '".mysql_real_escape_string($userlocation)."', '".mysql_real_escape_string($userbiscuit)."', $usercountry') ";
$void = mysql_query($sql) or die(mysql_error());
// Send email
$subject = 'A note for Faldo';
$message = "The following details were entered on a form .\n";
$message .= "A line with some details $username $userlocation $userbiscuit.\n";
$message = wordwrap($message, 70);
$headers = 'From: The Web Page' . "\r\n" .
$headers .= "X-Mailer: PHP/" . phpversion()."\n";
$headers .= "Importance: High\n";
mail($to, $subject, $message, $headers);
// All went OK so redirect to another script.
header('Location:AnotherScript.php');
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head>
<title>Faldo Test</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
</head>
<body>
<form method="post" name="form1" target="_self">
<input type='text' id='username' name='username' value='<?php echo $username ?>' /><br />
<input type='text' id='userlocation' name='userlocation' value='<?php echo $userlocation ?>' /><br />
<input type='text' id='userbiscuit' name='userbiscuit' value='<?php echo $userbiscuit ?>' /><br />
<select name='usercountry' >
<?php
foreach($CountryArray AS $CountryId=>$CountryName)
echo "<option value='$CountryId'".(($usercountry == $CountryId) ? "selected='selected'" : '' )." >$CountryName</option><br />";
</select>
<?php echo $ErrorMessage; ?><br />
</form>
</body>
</html>
 Posted: 16:53 - 22 Jun 2010 Post subject: |
Excellent Keith, a lot of that makes some sense to me. I'll have a play about with them tomorrow.
Thanks . |
