Rear Pads
rac3r
PostPosted: 09:35 - 26 Jun 2010    Post subject: Rear Pads Reply with quote
My rear pads are just about shot on the Monster and whatever was in there was absolutely crap!
Any advice on a replacement? I know it's only the rears so I don't want anything too 'good' that will keep locking up all the time. Also a link to where I can get them would be good Thumbs Up
Chequered Flag
Rob W
PostPosted: 09:46 - 26 Jun 2010    Post subject: Reply with quote
Look on eBay for a set of Goldfren's, half the price of the competition and easily as good IME.
rac3r
PostPosted: 10:39 - 26 Jun 2010    Post subject: Reply with quote
Err...
Goldfren Carbon Cermic £12.99
Brembo rears £20
Chequered Flag
LeeR
PostPosted: 10:52 - 26 Jun 2010    Post subject: Reply with quote
I've put some Kyoto organic pads from Wemoto on my DL1000 (sintered are just too much for the suspension) and they're a lot better than the OEM Nissin pads, dunno how they'd behave on a Monster but for £10/pair it might just be worth a try.
My claim to fame: Austin Vince nicked my pen...
rac3r
PostPosted: 10:57 - 26 Jun 2010    Post subject: Reply with quote
What I want to know is are the Brembo pads so good they cost double or is it just the badge as usual?
Chequered Flag
Marmalade
PostPosted: 11:17 - 26 Jun 2010    Post subject: Reply with quote
Go with the goldfren HH, last ok and stop good, i use them on Pan euro and zzr6
If they work too well and keep locking up, you could try some WD40 on the discs or maybe a riding school
KLR600
PostPosted: 23:47 - 26 Jun 2010    Post subject: Reply with quote
I used to be a Goldfren endorsee but the last set of rear pads I bought had both the braking surfaces fall off the metal bit of the pad Shocked Won't be going there again.
<Take Cool Photos!>
Dazbo666
PostPosted: 09:10 - 27 Jun 2010    Post subject: Reply with quote
I used Kyoto pads on the GPZ in the past, and I'd highly recommend them. Seemed to be just as good as the EBC / OEM pads that they replaced, and about 60% of the price.
On the other end of the scale, I recently used some cheapo Armstrong pads on the Bandit, and managed to wear the front pads almost down to the metal in <2 months
Word of the day : DILLIGAF
PostPosted: 11:03 - 27 Jun 2010    Post subject: Reply with quote
I'd go EBC or Brembo, Last time I bought shit pads I changed them for good ones after a few hundred miles anyway. Anyway what is £8 over 10,000 miles or however long they last,
rac3r
PostPosted: 11:50 - 27 Jun 2010    Post subject: Reply with quote
I might just go for the Brembo's and be done with it
Chequered Flag
Rob W
PostPosted: 13:14 - 27 Jun 2010    Post subject: Reply with quote
I've done about 2.5K on a set of Goldfren's on the Thou, and they're holding up perfectly well, still got loads of meat on them, and just as competent at stopping you from silly speeds as the previous EBC pads.
rac3r
PostPosted: 13:18 - 27 Jun 2010    Post subject: Reply with quote
Quick question: Do you guys remove the calliper when changing pads? My haynes manual says to do it without removing
Chequered Flag
Rob W
PostPosted: 13:24 - 27 Jun 2010    Post subject: Reply with quote
I do yes. I cant see how you can do it without whipping them off? It only takes 2 minutes anyway.
rac3r
PostPosted: 13:41 - 27 Jun 2010    Post subject: Reply with quote
I can see it being a bit fiddly without taking them off Laughing
If I take them off I'll probably clean them too. When putting them back on do they HAVE to be the exact torque settings or can I just do them tight. (I have no way of measuring the torque)
Chequered Flag
Dazbo666
PostPosted: 13:50 - 27 Jun 2010    Post subject: Reply with quote
Yes I take them off. Not sure how I'd do it without removing them TBH.
I keep the brake lines connected so that I don't have to re-bleed the system. And I'm just careful not to twist or stress the lines or connections etc unneccessarily while fiddling with the calipers and pads.
I changed the front pads on the Bandit just yesterday. Prob <20 minutes for both sides, including the time it took to find the right sized sockets etc Thumbs Up
[EDIT: I don't use a torque wrench very often (and never used it on caliper bolts. I tend to tighten the bolts with a socket wrench until there's resistamce, then tighten maybe a further eighth of a turn.
Disclaimer : I don't claim that this is the proper, and certainly not the official technique, but it's worked for me for years, including the time that I worked at a commercial HGV garage.]
PostPosted: 14:37 - 27 Jun 2010    Post subject: Reply with quote
Some calipers you can load from the top without taking them off, personally I clean my Brake pistons when I change the pads so would take them off.
Rob W
PostPosted: 17:29 - 27 Jun 2010    Post subject: Reply with quote
Get yourself a torque wrench. It's surprising how 'loose' things can feel with a torque wrench, when your mind tells you it should be a lot tighter. I did the fork seals on the 595 last week, and as I didn't have a torque wrench handy I just did things up roughly as tight as I thought they should be. When I popped back in the morning, pretty much everything I'd 'nipped' up the night before was over-tightened, including my caliper bolts.
One of the main reasons people fcuk threads, things get tightened far more than they actually need to be.
The last post was made 16 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.98 - MySQL Queries: 15 - Page Size: 96.76 Kb
