Updating modem/router firmware
Mr.Everready
PostPosted: 14:59 - 01 Jul 2010    Post subject: Updating modem/router firmware Reply with quote
I'm having problems with bandwidth allocation on my router, I'm hoping the new firmware will have something in it for this.
So, I've never updated firmware on anything. Is it straight forward enough ? I've had this router for years and I'm not sure if I still remember my bb password etc. does the update scratch everything ?
Anything I should know and look out for ?
Bubbs
PostPosted: 15:15 - 01 Jul 2010    Post subject: Reply with quote
With netgear it's really straight forward. You download the firmware update, go onto the router menu which is 192.168.0.1 (off the top of my head) and then go to firmware update and point it to the file on you computer then it upgrades and restarts then all done.
I've only ever used netgear.
Ingah
PostPosted: 18:11 - 01 Jul 2010    Post subject: Re: Updating modem/router firmware Reply with quote
Usually as simple as something within the config pages.
Some can be told to update and they'll fetch the firmware themselves, but most of the routers i've used you need to find and download the firmware yourself first, and then go and upload it to the router via your web browser (again within the config pages).
Then just hope to hell that you don't get a power cut within the next few minutes Wink
Settings are usually wiped, so it would be wise to write them all down, or take a load of screen captures, so that you can put the settings back to how they were if it isn't working right.
-- Ingah
Serendipity
PostPosted: 21:53 - 01 Jul 2010    Post subject: Re: Updating modem/router firmware Reply with quote
Netgear firmware updates do not wipe the config, at least not on any of the routers I've set up. However you didn't specify make. I've done updates on Belkin, Linksys and Zyxel, but to be honest I can't remember if they get wiped or not.
If you want to take a belt and braces approach you should find a utility in the management interface to take a backup of the config. That way you're covered if the update does a factory reset.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
neil.
PostPosted: 22:15 - 01 Jul 2010    Post subject: Reply with quote
Also don't do it over Wi-Fi, hook up some CAT5 and update over Ethernet. Thumbs Up
herulach
PostPosted: 22:32 - 01 Jul 2010    Post subject: Reply with quote
By bandwidth allocation do you mean a QoS/packet shaping kind of program? If so I can't see a firmware update changing anything.
On our router I find it works better if you set the low priority packets and leave the high priority ones on their own. In my case that basically means BT and FTP down the bottom.
You may find you still experience lag in games with the QoS on anyway due to the number of packets the router has to handle.
YBR 125>FZS600
CaNsA
PostPosted: 00:08 - 02 Jul 2010    Post subject: Reply with quote
Which router is it? there maybe some 3rd party firmware avilable for it.
I use DDWRT on my linksys gear and routertech on my adsl modem
The last post was made 16 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 52.68 Kb
