brakes
mr.kris
PostPosted: 15:29 - 04 Jul 2010    Post subject: brakes Reply with quote
Been haveing a shity time trying to sort my brakes out. Iv just noteced that if i put a set of grips on the hose to crush it. (non braided) The lever feels perfect. Soon as i take them off it feels like shit again. We thinking new lines or am i missing something????? thanks
xxxx
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
PostPosted: 16:08 - 04 Jul 2010    Post subject: Reply with quote
There's still air in there somewhere.
Blue_SV650S
PostPosted: 17:27 - 04 Jul 2010    Post subject: Reply with quote
Or the calliper pistons are retracting too far ...
mr.kris
PostPosted: 17:52 - 04 Jul 2010    Post subject: Reply with quote
iv bled the shit out of it no air comeing out anyware that i can find left it straped up overnight to nothing is bloody helping oh and there 6pots of gayness if that helps!
Blue_SV650S
PostPosted: 18:09 - 04 Jul 2010    Post subject: Reply with quote
how worn are the pads?
mr.kris
PostPosted: 18:10 - 04 Jul 2010    Post subject: Reply with quote
they got plenty of life left in them
That_Hornet
PostPosted: 18:55 - 04 Jul 2010    Post subject: Reply with quote
Air behind the pistons?
Noxious89123
PostPosted: 23:35 - 04 Jul 2010    Post subject: Reply with quote
Which bike? Front brakes or rear? You say 6 pots so I presume it the ZX6R. Are you clamping the hose near the master cylinder, or at the end nearest the caliper?
Have you tried pressurising the brake system, and then cracking open one of the banjo bolts to let any trapped air out? That's where I got air trapped with my rear brake, as it sits higher than any part of the caliper.
Taking the calipers off, tapping them with something solid but soft (wooden mallet, screwdriver handle, or your hand) and moving them about can help get air out too.
Apologies if I'm "teaching my granny to suck eggs".
PostPosted: 23:37 - 04 Jul 2010    Post subject: Reply with quote
If they are the 6 pots then strip and clean the calipers thoroughly, especially behind the seals. Could well be worth replacing the seals while you are at it.
mr.kris
PostPosted: 18:07 - 05 Jul 2010    Post subject: Reply with quote
thanks for the replys i orderd some braided lines last night so when they come i will do all of the above and let you know how it works im predicting the best brakes ever Rolling Eyes Wink any one wana rebuild them for me as they are gay to work on lol
Fisty
PostPosted: 18:57 - 05 Jul 2010    Post subject: Reply with quote
Your bike has contracted the aids. It needs a newcaliperectomy.
Fatter and faster than Fret
mr.kris
PostPosted: 19:03 - 05 Jul 2010    Post subject: Reply with quote
wana sort me out with some mega ones on the cheap ????? ?X ?X? X??XX? ?X ?X X? ?X ?X X??X ?X ?X ?X ?X ?X
TUG
PostPosted: 21:09 - 05 Jul 2010    Post subject: Reply with quote
OMFG all this shit again, listen up bcf, its tokico calipers, run a google search on them they all do it!
If it is air remove the calipers and clamp off a hose, bleed per caliper but its the pistons getting pulled in by the seals ala "seal roll" its not air, its not anything else, its because the seal seat has worn too much and the only fix is new calipers as far as i see it, my SRAD does this, and sophies zx6r does it, and it fucks me off, i've tried every thing under the sun to no success, tieing the lever over night gives some pressure but soon fades as soon as you pump the lever.
Haz ER-5, innit!
Fisty
PostPosted: 21:17 - 05 Jul 2010    Post subject: Reply with quote
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150463483151&ssPageName=STRK:MEWAX:IT
Put these on instead
Noxious89123
PostPosted: 21:26 - 05 Jul 2010    Post subject: Reply with quote
Can't remember the persons name, but someone on here changed the tokico 6 pots on his ZX12-R for some very saucy looking Nissin 6 pots.
rob c
PostPosted: 06:59 - 06 Jul 2010    Post subject: Reply with quote
Had the same with the 6 pots on my zx9 found it was the dust seals to blame so took them out and put red rubber grease in them bled the brakes again with the calipers OFF the bike so I could turn the caliper around so any air would always be going upwards following the oil ways through the caliper, ended up with one finger braking.
DrDonnyBrago
PostPosted: 12:06 - 06 Jul 2010    Post subject: Reply with quote
My bro (bacon) did the same on his ZX-7R, they are bandit 12 or GSXR750 calipers IIRC...
tutton
PostPosted: 12:11 - 06 Jul 2010    Post subject: Reply with quote
bandit 12, and they were 4 pots he stuck on not nissin 6 pots Wink
DrDonnyBrago
PostPosted: 15:45 - 06 Jul 2010    Post subject: Reply with quote
Reading fail Thumbs Up .
Noxious89123
PostPosted: 19:54 - 06 Jul 2010    Post subject: Reply with quote
And from a bandit, they'd also be Tokico, not Nissin. Double fail Laughing
I meant like these;
https://img36.imageshack.us/img36/6646/newpa8.jpg
Drooling
https://www.fwr.co.uk/nissin.htm
£175 each.
bacon
PostPosted: 00:46 - 07 Jul 2010    Post subject: Reply with quote
fail.... bandit 12's had nissin 4 pots, not tokicos Wink
my nissin 4 pots are the same as those fitted to bandit 12's etc, my exact pair came from an old gxsr 1100 (was this the slingshot model?)
either way the 4 pots are easy to bleed, wont get so easily fucked in winter like the 6 pots, £40 to replace all seals instead of £60, and best of all, they cost me £42inc with brand new pads (my 6 pots needed new pads soon anyway as well as almost all new dust seals)
Cool
PostPosted: 11:18 - 07 Jul 2010    Post subject: Reply with quote
Later ones had the troublesome 6 pots.
The last post was made 16 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 119.75 Kb
