Daytona 600 electrical issues
PostPosted: 21:34 - 05 Jul 2010    Post subject: Daytona 600 electrical issues Reply with quote
ok, im no fan of electrics...but this is annoying me.
basically i was going to work today, nearly at work i noticed the clock went off..and came back on.
thought nothing of it.
went to leave work and i disabled alarm, put key in and turned it to on. fuel pump primed and dash checked everything..hit the starter and the clocks went.
went to bump it and it seemed after i "rocked" the bike or rolled it forwards/backwards or hit the brake it allowed me to fire the bike up.
ragged it home, just incase it was an iffy battery, got it home and checked, 12.6v off, 11.99v with key on position (lights come on auto) and 13.90v - 14.14v running.
When i turned the bike off after the ride home it did the same as when i left work.
just went to start it now, 3 hours after leaving it...and its done the same.
main problem is the trip resets, the clock goes to 1pm...and i need the time Laughing
alarm wise i have a datatool s3 i think..
anyone shed any light on this piece of garbage?
Laughing Karma
0l0dom0l0
PostPosted: 21:52 - 05 Jul 2010    Post subject: Reply with quote
freind had a simular problem. bike would bump start fine and we could ride for 30 mins, he would stop, try to start again and the same problem your having would occur.
its the clocks resetting from where there is to much draw on the battery and it cant cope, ie nackered battery.
he got a new battery and all is fine now. (he has the same alarm too btw).
hope this helps.
PostPosted: 22:22 - 05 Jul 2010    Post subject: Reply with quote
battery is new, voltage doesnt actually drop much when cranking chris, down to 10.5, but turns over fine.
ive just had the same issue..but i just shook the handlebars and it burst into life.
I think i may have a loose connection.. Sad
andys675
PostPosted: 23:56 - 05 Jul 2010    Post subject: Reply with quote
you've got a dirty connection in one of the block connectors, pull them apart and look for the one with all the green stuff on the copper connectors
PostPosted: 08:38 - 06 Jul 2010    Post subject: Reply with quote
i'll have a look, whats worse is i lost all form of speedo last night.
It registers 0 all the time then goes blank, so i'll look for connectors
Rowey
PostPosted: 08:53 - 06 Jul 2010    Post subject: Reply with quote
Just so you know. On my TT600 when I hit the starter, the clocks also go out, but come back fine once the bike has started. The trip and time does not reset, and there is never any other power 'trips' during riding.
Get yourself some dielectric grease and Cilit bang and clean all of the connectors, then grease them up. Not sure what metal the connections are but Cilit bang works brilliantly on copper.
Then check the battery, and then check the charging system. If you look in the workshop section for a TT600 restoration, I've posted a guide on how to check the charging system on these bikes.
ZX6R C6F.
PostPosted: 15:01 - 06 Jul 2010    Post subject: Reply with quote
Thanks for that.
By hit the starter i mean, usually it just cranks over and the clocks stay on, now it just kills the whole system Sad
Im about to have a look at the connectors now.
The last post was made 16 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 52.11 Kb
