Adding 2 HardDrive's RAID 0 Vista
Luke_Retrofly
Silly Lesbian
PostPosted: 16:00 - 06 Jul 2010    Post subject: Adding 2 HardDrive's RAID 0 Vista Reply with quote
Basically I have Vista 64bit installed to a single harddrive.
I want to add 2 more drives and stick them in as a RAID 0.
So I'll have my nomral C:\ drive, plus another RAID 0 array e.g E:\
Is this possible, is it easy to do?
Flounced - Long overdue
Fuck you bitch I'm in the top 10 list I can do the what the fuck I want!
supZ
PostPosted: 17:15 - 06 Jul 2010    Post subject: Reply with quote
if your motherboard supports raid then yes its a piece of piss.
plug em in, goto raid utility (press whatever button it tells you to press on post) put em both in an array (raid-0 stripe/mirror - whatever you want) save it then load up windows.
install the raid drivers you got with your mobo, find the drive and create your partition/format it and voila. new drive.
if your mobo cant handle it then err.. its gets more complicated. although you can use windows to setup a software raid. never used it tho so dont know if its any good.
failing that you could buy a raid card (for whatever connections your hdds have.. im guessing they're both sata) and set it up roughly as if it was the onboard version i mentioned above.
pretty straight forward to do.
only gets complicated when you're trying to install windows on a raid array with no floppy drive Very Happy although these days usb flash drives work wonders..
CBR954RR - Daily toy
CBR600RR - Trackbike
Pernig
PostPosted: 19:59 - 06 Jul 2010    Post subject: Reply with quote
I'd be wary about using your motherboard's on-board RAID controller as if your motherboard breaks you need to buy an identical motherboard to get your data back in RAID 0.
H100 Breaking for spares
Colin Edwards
PostPosted: 22:10 - 07 Jul 2010    Post subject: Reply with quote
So you want to take 3 drives and have one as system and the other 2 as a 2nd drive?
If so use the built in software raid in fista (in disk manager)...
CE
Colin Edwards
PostPosted: 22:12 - 07 Jul 2010    Post subject: Reply with quote
Ignore the start going on about 2008 :
https://technet.microsoft.com/en-us/library/dd163558.aspx
CE
The last post was made 16 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 44.78 Kb
