Does this make sense for downgearing the bike.
Crazy Assed Goose
PostPosted: 20:42 - 06 Jul 2010    Post subject: Does this make sense for downgearing the bike. Reply with quote
At the minute I have 15T on the front and 40T on the back. I have bought a 14T front. Have fitted it, then went back to 15T can't decide which one I prefer.
I like having the 14T, but like having a spot on accurate speedo (measured with GPS correct exactly up to 50mph, not tried any higher).
Am I right in saying that if my speedo is accurate with a 15T on. Then with a 14T on it will read:
15/14 = 1.07 times my acctually speed?
This makes sense as top speed in 6th is 130, but the speedo was reading 140, 130 x 1.07 = 140.
So since most speeds over read by upto 10% this put my speedo about the same accuracy as most other people?
So then my annoyance about speedo inacuracy is gone as it is like before I got the km/h converter so I can go back to 14T sprocket?!
Will I miss those 5mph top speed though?! lol probably not
[The reason my speedo is more accurate with original gearing is because it was in km/h, then when I put the mph converter in it made it spot on since when they have made it they made it so it would convert to true speed.]
herulach
PostPosted: 20:53 - 06 Jul 2010    Post subject: Reply with quote
What bike is it? Where does it take the speed sensor from? If it's off the front wheel it won't make a difference.
YBR 125>FZS600
Crazy Assed Goose
PostPosted: 20:55 - 06 Jul 2010    Post subject: Reply with quote
NC30 from the front sprocket. I does make a difference I have had both on before, I had put 14T then changed back to 15T now thinking of going back again to 14T.
herulach
PostPosted: 21:01 - 06 Jul 2010    Post subject: Reply with quote
In that case your maths look right. is your mph converter adjustable in any way?
YBR 125>FZS600
Crazy Assed Goose
PostPosted: 21:33 - 06 Jul 2010    Post subject: Reply with quote
No it just goes between the speedo cable and the speedo, it is just a small gearing system to slow down the rpm of the speedo cable.
PostPosted: 10:28 - 07 Jul 2010    Post subject: Reply with quote
Your maths is right. Surprised the mechanical kmh / mph converter made it more accurate.
The last post was made 16 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 48.64 Kb
