2005 aprilia rs50 wont start. why ???
minisidd
PostPosted: 00:06 - 08 Jul 2010    Post subject: 2005 aprilia rs50 wont start. why ??? Reply with quote
hey ive just got an aprilia rs50 (2005 model ) and i went out on it for the first time today.
I stalled it a few times as ive just past my cbt. i stalled and the bike wouldnt start again so i had to wheel it home. charged the battry thinking it was that and still didnt start. then i knotised that it wasnt turning over as i tryed to start it and i could only hear a click as i pressed the electric start butten any idea what's up with it and how do i fix it ?
tom
Paddy Blake
PostPosted: 00:58 - 08 Jul 2010    Post subject: Reply with quote
First disconnect the battery and then clean/sand the connections.
Then see where the red wire goes from the battery and clean/sand there.
Was it being used before you got it.?
wr125x2011
PostPosted: 10:04 - 08 Jul 2010    Post subject: Reply with quote
If it woulnt start after you kept stalling it, could be flooded, take out the spark plug, clean it with a wire brush or put a new one in, try starting the bike again, if not bump start it, first gear, hold in clutch, run along or downhill and release clutch should start. Thumbs Up
dobby
PostPosted: 10:07 - 08 Jul 2010    Post subject: Reply with quote
clicking will most probably be comming from the starter relay, try using a jump pack to boost the battery if that works then charge your battery or get a new one, or if it still clicks then you know its the relay or a corroded switch Thumbs Up Very Happy
-Savage-
PostPosted: 11:48 - 08 Jul 2010    Post subject: Reply with quote
Really sounds like your battery is dead, what type of charger did you use?
minisidd
PostPosted: 14:46 - 08 Jul 2010    Post subject: Reply with quote
not to sure but i think it was one that was for bikes or least it looked it and thanks ill have to try it an see what happens
tom
dobby
PostPosted: 15:14 - 08 Jul 2010    Post subject: Reply with quote
so if its not turning over + clicking sound = starter relay buggered...
i can lay money on it... as these are a common fault same as on the later models and gpr50s the starter bendix would kill the flywheel
bikertomm
PostPosted: 20:29 - 08 Jul 2010    Post subject: Reply with quote
Go and bump start it and see what happens Mr. Green
minisidd
PostPosted: 20:36 - 08 Jul 2010    Post subject: Reply with quote
by bump start you mean run and try n start it ? and we did today after we got a new spark plug haha bonus it has a race spark plug Very Happy and yeah it starts but try n start it normally n it dont so most be the starter motor haha oh well least now it starts all thats left is the spedo cable to get here and put on and should be good to go Very Happy
tom
wr125x2011
PostPosted: 20:46 - 08 Jul 2010    Post subject: Reply with quote
yeah thats bump start, sounds like the battery then, if its still starting when you bump it surely its not the starter motor as its starting? D:
Digitalize
PostPosted: 20:47 - 08 Jul 2010    Post subject: Reply with quote
Fuse has blown, mine had the exact same (not an RS50) Need to find the fuse, and replace. Should be fine then.
Or Battery is dead, mines actually done both thinking about it. Basically identical symptoms.
Check the fuse first though, its a 50p part.
1998 CB600F Hornet
minisidd
PostPosted: 20:48 - 08 Jul 2010    Post subject: Reply with quote
yeah dads say that today as well haha its just finding it coz for some reason it has alot of fuses on this bike Razz
tom
The last post was made 15 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 72.59 Kb
