Bandit 600 - please help??
GSF Jamie 600
PostPosted: 18:05 - 08 Jul 2010    Post subject: Bandit 600 - please help?? Reply with quote
My bike is having some issues, the bike starts fine but misfires and runs on 3 cylinders Sad Now this doesn't happen evertytime but occasionally.
It then ride like a bag of bones until about 15-20 miles later where it just picks itself up and runs sweet again Embarassed
So my question is what could be wrong with it, does in need the carbs cleaning, carbs balancing or could it be something else Confused
Its a 97 Bandit 600 with 9k on the clocks, it has had a recent oil change, new iridium spark plugs and a new air filter.
If anyone could shed some light on this or just some advice, it would be greatly appreciated Karma
Many thanks
Jamie Thumbs Up
Teflon-Mike
tl;dr
PostPosted: 18:49 - 08 Jul 2010    Post subject: Re: Bandit 600 - please help?? Reply with quote
When are you using the choke?
3-pots on start up, does sound like carbs could do with some attension, but rough running till warm, is a warm up problem and teh starting point for that is whether you are knocking teh choke on for start up and then off too early or something.
GSF Jamie 600
PostPosted: 19:59 - 08 Jul 2010    Post subject: Re: Bandit 600 - please help?? Reply with quote
Thanks for the reply,
yes i use the choke on start up, and let it warm up for a few mins whilst i'm getting my gear on Confused
So its most definately a carb issue as it had 3 cylinders on start up?
PostPosted: 20:29 - 08 Jul 2010    Post subject: Reply with quote
Not certainly the carbs, no. Could also be a ignition related such as plug, HT cap or plug lead (most other things would affect 2 cylinders). Also it could be valve clearances.
My first guess would be the plugs. If you are unsure then swap the plug between the cylinder than is playing up and one of the others and see if a different cylinder misbehaves.
GSF Jamie 600
PostPosted: 21:44 - 08 Jul 2010    Post subject: Reply with quote
The spark plugs were brand new just the other week, and i had them out the other day to clean them up, but they weren't even dirty.
The issue was present before i bought the new plugs as i thought this may remedy it Confused
Oh bugger i hope its not valve clearances as i've heard thats a pricey job Crying or Very sad
HT cap or plug lead
Would these problems not be constant though, as my bike seems to clear it cheast and run fine after a while Rolling Eyes in saying that i'm a newbie to this so i could be talking rubbish Confused
So things to check;
HT cap or plug lead
Carbs
Is there anything else i should check or will the fault lie within these three?
Many thanks for your replys Karma
PostPosted: 21:56 - 08 Jul 2010    Post subject: Reply with quote
Not really. Bandit uses screw and locknut valve adjustment which is pretty quick and cheap.
Most likely yes, but not impossible. Especially if the problem is caused by water in there allowing things to short out until it steams off.
doggone
PostPosted: 22:23 - 08 Jul 2010    Post subject: Reply with quote
Maybe an ignition coil is on the way out, they sometimes do odd things like run OK for a while then fire intermittently.
There will be two, each does two cylinders.
evoboy
PostPosted: 00:57 - 09 Jul 2010    Post subject: Reply with quote
+1. Very easy to do the valve clearances on that motor.
APT Motorcycles
GSF Jamie 600
PostPosted: 09:01 - 09 Jul 2010    Post subject: Reply with quote
But its only dropped one cylinder and not two?
It's the as you look from the front the 2nd one in from the right Confused
Can a dodgy ignition coil cause just one to be dropped or is it always 2?
Karma
doggone
PostPosted: 10:14 - 09 Jul 2010    Post subject: Reply with quote
I wouldn't rule it out - You could swap them over to test.
The last post was made 15 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.35 - MySQL Queries: 13 - Page Size: 71.59 Kb
