Overheating Laptop
Martay
PostPosted: 21:54 - 12 Jul 2010    Post subject: Overheating Laptop Reply with quote
Hi,
My laptop has been playing up for a couple of weeks, and its getting really annoying. It will run fine, but after a couple of hours of being on, will suddenly shut off, i believe due to it overheating. It doesnt shut down properly, just goes off. The cooling fan does run, but obviously isnt very effective.
I have it sat on a large hardback book to help get airflow underneith it, to no avail Sad
I was thinking of making a little platorm thing for it to sit on, with a large fan from a PC mounted in it, blowing into the vents underneith. Nothing massive, about the same size as the book it is currently sat on.
I was going to run the fan from the laptops USB port, disecting an old mobile phone cable. What do you think to this?
Essay over. BTW, its an Acer Aspire Gemstone i think!
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
panrider_uk
PostPosted: 22:48 - 12 Jul 2010    Post subject: Reply with quote
My HP netbook used to run hot. I removed the plastic mesh that covered the vents and it runs about 20C cooler now (and more importantly the fan isn't always on making a racket).
Mark
Itchy
PostPosted: 22:55 - 12 Jul 2010    Post subject: Reply with quote
My dell runs like a nuclear reactor hot..
Get thee a laptop cooler thingie? I bought my USB one for £6.
Oh and clean the air vents with a can of compressed air.
r0b
PostPosted: 15:50 - 13 Jul 2010    Post subject: Reply with quote
when this happens i disassemble the laptop and clean all the fluff out of the copper heat pipes and fan areas
'92 Honda NX650 Dominator RD02
'98 Kawasaki ZX9R C1
'00 Yamaha TT600R Belgarda
Serendipity
PostPosted: 18:09 - 13 Jul 2010    Post subject: Reply with quote
r0b wrote:
...clean all the fluff out of the copper heat pipes and fan areas...
Agreed.
On a couple of occasions I have seen heat pipe failures. If the pipe develops a leak causing the vacuum to fail and/or the working fluid to escape then it’s rendered useless. This is only something to suspect if the heat sinks are scrupulously clean with good airflow yet the device continues to overheat.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
Scotsman37
PostPosted: 20:51 - 13 Jul 2010    Post subject: Reply with quote
Get a can of compressed air say from Misco or Tescos and blast the openings around where the processor is situated, and by doing this you may blow all the crap trapped inside.
I had this problem in the past and doing the above cured it!
The last post was made 16 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 49.36 Kb
