GP100/125 Carb question
cb1rocket
PostPosted: 13:42 - 12 Jul 2010    Post subject: GP100/125 Carb question Reply with quote
Hi Guys
I'm wanting to double check the connections of my pipes to the carb, but as one pipe is missing, I want to make sure its nothing serious.
I have put it down as being so far as the picture says, to which I believe what is what.
Can anyone confirm the same?
1. Oil pipe (quite far back and has a needle inside when you open the throttle and look down the bore, which finishes centrally in the bore0
2. don't know
3. Fuel Pipe (def is as petrol pours out)
4. drain tube ( i think so)
5. Overflow tube ( is it?!)
https://i212.photobucket.com/albums/cc108/CB1Rocket/CARBINFO.jpg
cheers
neil.
PostPosted: 13:57 - 12 Jul 2010    Post subject: Reply with quote
Don't know your carb or if you've hooked everything up right, but I'd imagine #2 is possibly a breather.
PostPosted: 14:54 - 12 Jul 2010    Post subject: Re: GP100/125 Carb question Reply with quote
cb1rocket wrote:
2. don't know
cheers
Ok Judging by my RD350 carb which is a Mikuni VM 28 (yours looks like a Mikuni, but I might be wrong) then the numbers are as follows:
1) It is difficult to see but looks like an oil feed pipe.
2) Looks like a vacuum choke pipe
3) Fuel pipe
4) Looks like another oil feed, but its on the bottom of the float chamber so I'm not sure
5) Definitely an overflow.
1 and 2 might be the wrong way around as it isn't identical to my bikes carb...
cb1rocket
PostPosted: 16:55 - 12 Jul 2010    Post subject: Reply with quote
did check number 4 and its not connected to anything.
Still bothered about no. 2 thou! As usual Haynes is crap
cb1rocket
PostPosted: 17:02 - 12 Jul 2010    Post subject: Reply with quote
oh and about the choke, its cable operated which can be seen on the upper most right past the throttle slide
cb1rocket
PostPosted: 22:05 - 12 Jul 2010    Post subject: Reply with quote
any one with news on connection no. 2? cheers
PostPosted: 22:32 - 12 Jul 2010    Post subject: Reply with quote
My guess would be that it is for a vacuum choke for a second carb. It certainly looks like the vacuum connection on my RD. Perhaps that model of carb is used on twin cylinder bikes?
cb1rocket
PostPosted: 23:22 - 12 Jul 2010    Post subject: Reply with quote
Thanks MarJay.
The haynes shows it as a clear plastic tube going over it - any hints on that?
Interesting to say its could be a vacumm operated choke.
Any Suzuki GP100/125 owners on here or have owned and done there own servicing on these bikes?
serlant
PostPosted: 03:09 - 13 Jul 2010    Post subject: Reply with quote
Friend of mine has a GP125 and a GP100 and we've had the carbs off both, i'll point him to the thread as i can't remember off the top of my head.
Ragnaco
PostPosted: 11:01 - 13 Jul 2010    Post subject: Reply with quote
directed here from serlant, Had a quick look at my gp125 this morning took some pictures.
https://i5.photobucket.com/albums/y189/Ragnaco/2010-07-13104225.jpg
I gave number 2 a good pull, It's defiantly connected to something.
https://i5.photobucket.com/albums/y189/Ragnaco/2010-07-13104234.jpg
Looks quite red? I have no idea what it could be, being red it makes me think 2stroke is passing through it but what do I know.
I know you said you looked in your haynes manual but I tried to find mine to see if you missed anything sadly I can't find the bugger, I'll keep searching and update if I find anything.
Current bike : Suzuki GP 125 1982
cb1rocket
PostPosted: 13:14 - 13 Jul 2010    Post subject: Reply with quote
Ragnaco
Thanks for replying with a pic, so its connected to something....hmmmm.
If you look at the small tube at the back, that's def the oil fee as I manage to trace that. You can also see that if you open the throttle fully, you can see a needle that finishes in the middle of the bore where the oil drops out.
So far i have it as follows in my original picture
1. Oil pipe
2. Still unsure!
3. Fuel Pipe
4. drain tube ( yes it is)
5. Overflow tube confirmed by Marjay
evoboy
PostPosted: 14:09 - 13 Jul 2010    Post subject: Reply with quote
https://www.bikechatforums.com/files/carby.jpg
Found on this site.
Altho i dont see how its correct.
Where you have the fuel hose seems correct. Im guessing its a VM type mikuni carb as used on many suzuki's?
Im swaying towards the nipple with nothing attached being a 2stroke feed for some reason. It seems the most logical.
Only way your really gonna tell is if you trace the pipes back.
Is the 2stroke fed into the inlet port via a pump on this bike? (between engine and carb) As that would make sense if the thin black tube runs down behind the carb. (thats how its setup on my GT250 anyhoo)
APT Motorcycles
Ragnaco
PostPosted: 14:55 - 13 Jul 2010    Post subject: Reply with quote
I might get some slack for this, but have you tried starting it up and seeing if anything leaks from where the little black pipe comes down? I'd take a general guess and say if nothing is leaking down then surely it's nothing to worry about.
Also before taking those pictures earlier I had ridden the bike for about an hour yet the tube looks like it hasn't seen a drop of liquid in it for it's lifetime.
Took a new picture.
https://i5.photobucket.com/albums/y189/Ragnaco/2010-07-13144431.jpg
1. 2stroke out pipe (to carb so number 1 the little black pipe is correct)
2. 2stroke oil pump
3. 2stroke oil in.
Also note the big pipe from the air filter box, the tube number 2 basicly heads up in that direction... so now I have no idea.
So to recap
1. Oil pipe (yes)
2. Still unsure! (It's going somewhere to the airbox, breather?)
3. Fuel Pipe (yes)
5. Overflow tube confirmed by Marjay (yes)
On a different note can I see some pictures of the bike? Smile
PostPosted: 16:59 - 13 Jul 2010    Post subject: Reply with quote
I know what it is I think.
Could it be a vacuum feed for a vacuum operated fuel tap??? Exclamation Exclamation Exclamation
Ragnaco
PostPosted: 17:42 - 13 Jul 2010    Post subject: Reply with quote
gravity fed taps and lines.
Ragnaco
PostPosted: 17:51 - 13 Jul 2010    Post subject: Reply with quote
well I have 2 suzuki GP's a 125 and 100cc both have the same carb as cb1rocket has posted, I doubt all 3 have had their carbs swapped out.
most likely just a breather.
Ragnaco
PostPosted: 17:59 - 13 Jul 2010    Post subject: Reply with quote
pift, slightly.
cb1rocket
PostPosted: 21:21 - 13 Jul 2010    Post subject: Reply with quote
the carb i have matches exactly the one as shown in my haynes manual - Ragnaco carb is very similar but essentially the same setup.
Ragnaco could you pull on the clear (now discoloured red) tube away? or is it fixed to something? will get some pictures up, by the way it has a different wheel at the back - a gs125 alloy!?!?
Ragnaco
PostPosted: 21:45 - 13 Jul 2010    Post subject: Reply with quote
I gave a good yank with reasonable force and it did not come free, Did not want to chance unhooking it from anything and not being able to get it back on Razz might just be the fact the tube is so old and rotten that it's turned into solid plastic Razz but Iv had the carb out several times before and that tube stays hanging in place.
I'm pretty sure it's nothing important if it's going up into the airbox like it looks like it can't be doing anything that important.
I have a set of alloys for this bike, never been bothered to clean them up and put them on though Id feel like a right prick riding my rust-bucket around with alloys on anyway, It's bad enough riding with my knees up around my ears.
cb1rocket
PostPosted: 22:00 - 13 Jul 2010    Post subject: Reply with quote
well i had to take off my alloy and give it a good spanking clean and strip off the black flaking paint, still got some tight area which i will nitromors later once it passes the MoT - its been laid up for 7 years! I have a wire wheel on the front and a alloy on the rear - stupid me thinks - so i bought a gs125 front alloy for 20 quid with disc of the same size. Cool Just got to get it fitted, but me thinks it won't be a stright swap and may have to change the bearings and spacer tube to suit.
Anyway about the carb, its just that when the bike runs, there is just no power above 1/3 throttle. Any higher than 1/3 throttle and the engine just dies. I know me thinks the carb is just so bloody gummed up, me thinks the main jet is blocked. So its just running on the pilot jet. Got some carb cleaner which i trying spraying stright into the bore and down the fuel connection. I just don't want to take the carb apart - I have stripped carbs before and its alot of work and then finding a gasket to replace the old one.
All this was as I took it to the MoT it basically had no power but sounds fine when ticking over. I had to push it home up the hill with a bit of leg pushing and loads of smoke! lol Embarassed
Ragnaco
PostPosted: 22:10 - 13 Jul 2010    Post subject: Reply with quote
iv took the carbs apart on both my GP's several times not alot of parts to these small carbs and the haynes manual talks you through it step by step. Screw the gasket, I never replaced it and it probably has not been replaced in the last 5years+ just did the float bowl up extra tight.
If you wanted to talk on msn something about other things on the bike (mine constantly comes into problems I have to botchfix up with serlant) PM an email or something.
The last post was made 15 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 130.01 Kb
