My NC30.
Crazy Assed Goose
PostPosted: 21:04 - 13 Jul 2010    Post subject: My NC30. Reply with quote
I bought it before I passed my test in March, from a dealer as I wanted a 400 sportsbike but couldn't find many locally. 2 weeks after I bought it a mint zxr400 came up locally for 400 pound less lol, but I like the NC either way.
1992
20000 miles ish
This is how I got it:
https://i814.photobucket.com/albums/zz61/AnthonyRobertGreco/01042010470.jpg
The right hand lower fairing was (can't really see in pic) cracked and ground down. But I road around on it then dropped it and really cracked the lower fairing, so went to halfords and got some black gloss spray paint, and bought a honda sticker from ebay for a CRV 4x4.
All sprayed up it looks good.
Also got a tinted double bubble screen but that cracked when I dropped it so I got a shoddy clear screen and sprayed it black.
https://i814.photobucket.com/albums/zz61/AnthonyRobertGreco/kdag.jpg
Looked a bit naff so I fixed the double bubble and put it on.
Also:
-kph to mph converter to de-restrict top speed
-Down one tooth on the front sprocket, redline in 6th is 130mph, so lost about 5mph top speed but is worth it.
-Sprayed and fixed the bar ends, mirrors, exhaust guard.
-New viper exhaust
-Some stickers to cover a crack in the fairing where the HRC one is, but put more on so it didn't look out of place.
-8x6 plate as the other one was getting burned from my exhaust
-Levers but they didn't fit so sent them back
-Set up suspension for my weight.
-rear sets but they didn't fit so got my money back, and ebay guy said I could keep them anyway so stuck the pegs and levers on the bike
Mainly cosmetic tat to be honest, but the engines are a fanny to tune.
I have a seat cowl that need painting and stickered to put on also. It will be black with red stipes to match what you can see.
Hope to get soon:
-Braided lines as the originals are from 1992 and bulge badly and make braking a bit unpredictable.
-Proper rear sets
-Suspension refurbed/revalved etc
-Possible new tyres but the Macadam 100x seem alright, they might get a bit of a bad press but I have had not problems with them.
-Wheels powder coated.
-Set up on a friends dyno
https://i814.photobucket.com/albums/zz61/AnthonyRobertGreco/22062010480.jpg
https://i814.photobucket.com/albums/zz61/AnthonyRobertGreco/22062010479.jpg
https://i814.photobucket.com/albums/zz61/AnthonyRobertGreco/22062010481.jpg
Carl_steveo
PostPosted: 21:12 - 13 Jul 2010    Post subject: Reply with quote
Very nice mate I like it.
Current: Honda Nsr 125
Live: Sunderland
craigs23
Mr Muscle
PostPosted: 21:20 - 13 Jul 2010    Post subject: Reply with quote
BT090s.
It's a legal requirement on any NC30.
Crazy Assed Goose
PostPosted: 21:32 - 13 Jul 2010    Post subject: Reply with quote
BT090s.
Yes they would be the ones I would get/ will be once these run out of thread, but I just can't justify the price when these still have plenty of thread left, to be honest I am willing them to run out Neutral
garth
PostPosted: 21:37 - 13 Jul 2010    Post subject: Reply with quote
Macadams never wear down. Ever.
Crazy Assed Goose
PostPosted: 19:34 - 14 Jul 2010    Post subject: Reply with quote
lol I know, in 4000 miles they don't seem to have worn even slightly.
On another note, with the suspension being 18 years old I think it could do with somthing done.
Do you think it is enough to get the oil changed and new springs on the front, and the oil changed on the back. Or should I get a the whole rear shock re sprung and re valved?
I would prefer the first as it is considerably cheaper, could I get away with it for will it need totally changed?
Crazy Assed Goose
PostPosted: 22:51 - 28 Jul 2010    Post subject: Reply with quote
Planning for this and next week:
Fit my braided lines and change brake fluid front and rear, do tomorrow.
Full service, already done all the little jobs for it in the haynes, now the oil change, spark plugs (40 quid for 4!) etc needs doing.
Full carb clean and mod, clean etc, rejet, drill slides, raise needles.
Front fork rebuild, new springs, new oil, spacers etc.
Send away the shock for a rebuild, and fit rear jack up kit, but this might have to wait as it means having it off the road a while.
Seat cowl is away to be painted black, will fit and sticker when it is done.
Will post as and when I do it.
Frost
PostPosted: 00:03 - 29 Jul 2010    Post subject: Reply with quote
Cosmetically i much preferred it as standard, far too many stickers on it now.
Fit my braided lines and change brake fluid front and rear, do tomorrow. Thats what mine had, and it had very decent brakes, so i highly recommend it!
Full service, already done all the little jobs for it in the haynes, now the oil change, spark plugs (40 quid for 4!) etc needs doing. Careful with those plugs, they are only little so easily cross threaded, and fixing a fucked head is a nightmare. Make sure you turn them in gently by hand as far as you can before getting the wrench to them.
Full carb clean and mod, clean etc, rejet, drill slides, raise needles. I think i ran 120 & 118 jets which worked well. 2 M3 washers under each needle also seemed to do the job.
Front fork rebuild, new springs, new oil, spacers etc. Heard very good things about the progressive springs
Send away the shock for a rebuild, and fit rear jack up kit, but this might have to wait as it means having it off the road a while.The shocks are pretty terrible by this age, i've heard a CBR shock is a good replacement?
This could be one awesome little bike! Smile
Crazy Assed Goose
PostPosted: 09:57 - 30 Jul 2010    Post subject: Reply with quote
Got the braided lines on, loads better. They were only 22 pounds from busters and came with everything, only the front lines though, and replaced the fluid in both systems.
Also ordered everything from Rick Oliver for the carbs and service. Get that done next week as I don't want it off the road at the weekend. Very Happy
Need to change the front tyre now and it's past the indicator, I am going to change the set and get the BT090s.
Sachstasy
PostPosted: 13:10 - 30 Jul 2010    Post subject: Reply with quote
Am I the only person that thinks these bikes are gorgeous. Nice one buddy Smile
2002 Sachs XTC Racing.
Crazy Assed Goose
PostPosted: 15:10 - 02 Aug 2010    Post subject: Reply with quote
Noooooooo. Binned it.
Enthusiastic cornering, some cunningly placed gravel.
All down the left side scraped, exhaust, mirrors, mirror bracket, front fairing, foot peg snapped off. Very Happy
Oh well, might repaint the whole thing, any ideas on a colour scheme that is easy to fix when I come off again?!
PostPosted: 15:14 - 02 Aug 2010    Post subject: Reply with quote
Hammerite Black.
Crazy Assed Goose
PostPosted: 23:24 - 02 Aug 2010    Post subject: Reply with quote
Took the fairings off so I can fix them and still use the bike without keep taking them off and putting them on.
Cut my cracked and broken screen down to protect the clocks from flys etc. It;s not streetfightered and is getting changed back asap.
https://i814.photobucket.com/albums/zz61/AnthonyRobertGreco/02082010485.jpg
https://i814.photobucket.com/albums/zz61/AnthonyRobertGreco/02082010486.jpg
Crazy Assed Goose
PostPosted: 16:24 - 09 Aug 2010    Post subject: Reply with quote
Been busy.
Fixed the fairings pretty much, still some slight scratches but decent enough for me until I drop it again lol.
The cable tie is holding it since I lost one of the half twist lock screws and don't know where to get one.
Carbs have been rejetted and fully cleaned and raised the needles by 0.5mm, got some new BT090s and they are spot on, gave it a full service, replaced the snapped foot peg, still need the seat cowl painted and suspension done.
Non double bubble screen is on now also since the other one was quite brittle and smashed in the drop.
https://i814.photobucket.com/albums/zz61/AnthonyRobertGreco/09082010487.jpg
https://i814.photobucket.com/albums/zz61/AnthonyRobertGreco/09082010488-1.jpg
https://i814.photobucket.com/albums/zz61/AnthonyRobertGreco/09082010489.jpg
New tyres, been to the edge and handles alot better now.
Billing
PostPosted: 14:55 - 10 Aug 2010    Post subject: Reply with quote
Looking good mate, although there's too many stickers for my liking. I may have one of those 1/4 turn screws from my CBR, if you get a ruler and measure the stem of the one on the other side you'll know what size to get, from memory they are 19mm ones. If you want some pretty ones have a look on ebay for '19mm dzus' if yours are 19mm ones, they're quite expensive, but look the dogs danglies!
The last post was made 16 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 91.3 Kb
