bandit 600 help wanted
basha8991
PostPosted: 22:18 - 14 Jul 2010    Post subject: bandit 600 help wanted Reply with quote
hi guys i have a problem with my bandit 600 ithe spark plug in the first cylinder keeps suttinng up and then failing to fire. i have checked the float hight in the carbs and its near a nuff bang on. i have had the carbs stripped, cleaned and balanced by a bike shop. have also checked the inlets and the air box for leaks and there all good... any suggestions or help would be great thanks
Mr Hammers
PostPosted: 23:09 - 14 Jul 2010    Post subject: Reply with quote
You could try swapping the coils over and then see if it does the same thing to the same #1 plug. If it does, then it still sounds like it might be a carb issue, if it doesn't, then it's probably the coil.
Oh, and I take it the very same plugs are in all four pots..?
A Guide To Powerbands
basha8991
PostPosted: 23:24 - 14 Jul 2010    Post subject: Reply with quote
yeah plugs are all the same i have purchased a second hand coil of ebay.gonna try that if it dont work, ill look bk at the carbs.
basha8991
PostPosted: 17:39 - 17 Jul 2010    Post subject: Reply with quote
coils are working correctly still no luck
Curtmeister
PostPosted: 21:49 - 18 Jul 2010    Post subject: Reply with quote
It sounds retarded but try and see if the plug is actually working. I bought a set of plugs once and one of them wasn't working so i'd check it even if it is new. Also check that the plug lead is fine Smile
Best of luck Smile
Bikes: 54 Reg Gilera DNA50 > V Reg Kawasaki BN125 Eliminator > P Reg Suzuki Bandit N600 > 57 Reg Suzuki Bandit 650
Cages: 58 Reg Vauxhall Corsa 1.25 CDTI
basha8991
PostPosted: 22:19 - 18 Jul 2010    Post subject: Reply with quote
yeah i have tried already no luck got iridum ones as well
Curtmeister
PostPosted: 22:50 - 18 Jul 2010    Post subject: Reply with quote
Good good. I've got iridiums myself, wish I'd checked what was in there before I changed them because it had dual electrode plugs in it. If it was a coil them two cylinders wouldn't firing. Drain your float bowls an see if theres any crap in the carbs. Don't really know what else to suggest sorry mate.
nowhere.elysium
The Pork Lord
PostPosted: 22:58 - 18 Jul 2010    Post subject: Reply with quote
Have you checked the HT lead for continuity? Alternately, as as been suggested, look at your carbs. May have one playing sillybuggers.
oriel dave
PostPosted: 00:43 - 20 Jul 2010    Post subject: Reply with quote
So have you swapped no1 plug for one of the others and the problem stays with no1 cylinder? If yes have you checked the valves?
If the problem is with the plug measure the gap yourself. I had a set of brand new plugs that made mine run like shit because the gaps were all wrong.
Europe Trip 2009
The last post was made 16 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 59.6 Kb
