| basha8991 |
 basha8991 Derestricted Danger
| Mr Hammers |
 Mr Hammers World Chat Champion
 Posted: 23:09 - 14 Jul 2010 Post subject: |
You could try swapping the coils over and then see if it does the same thing to the same #1 plug. If it does, then it still sounds like it might be a carb issue, if it doesn't, then it's probably the coil.
Oh, and I take it the very same plugs are in all four pots..? ____________________ A Guide To Powerbands |
| basha8991 |
| basha8991 |
| Curtmeister |
 Curtmeister Renault 5 Driver
 Posted: 21:49 - 18 Jul 2010 Post subject: |
It sounds retarded but try and see if the plug is actually working. I bought a set of plugs once and one of them wasn't working so i'd check it even if it is new. Also check that the plug lead is fine
Best of luck  ____________________ Bikes: 54 Reg Gilera DNA50 > V Reg Kawasaki BN125 Eliminator > P Reg Suzuki Bandit N600 > 57 Reg Suzuki Bandit 650
Cages: 58 Reg Vauxhall Corsa 1.25 CDTI |
| basha8991 |
| Curtmeister |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| oriel dave |
 oriel dave Nova Slayer
 Posted: 00:43 - 20 Jul 2010 Post subject: |
So have you swapped no1 plug for one of the others and the problem stays with no1 cylinder? If yes have you checked the valves?
If the problem is with the plug measure the gap yourself. I had a set of brand new plugs that made mine run like shit because the gaps were all wrong. ____________________ Europe Trip 2009 |
The last post was made 16 years, 30 days ago. Instead of replying here, would creating a new thread be more useful? |
