Brake disc spray ..
Paulington
PostPosted: 02:16 - 15 Jul 2010    Post subject: Reply with quote
I get some on there occasionally when cleaning the bike, you've just got no brakes until it wears off, usually a few 100 metres. After that you're fine. Laughing.
No reason to do it purposely though?
I do remember doing it in the kart though, 75mph into a 25mph hairpin! I think I needed new pants after that.
Billing
PostPosted: 02:24 - 15 Jul 2010    Post subject: Re: Brake disc spray .. Reply with quote
Rapdude wrote:
Does anyone spray their brake discs with wd40 and or acf50
No, not on purpose, or in any amount worth worrying about, mostly WD when cleaing the wheels.
Brakes work using friction, therefore anything that is going to reduce it is a bad thing to put on there, mmmmmmmmmmmmmkay?
johnsmith222
PostPosted: 05:03 - 15 Jul 2010    Post subject: Reply with quote
WD40 on brakes is a bad idea. It made my back brake useless when I was using it to lube a jr. hack saw to cut off my disc lock. I wasn't too bothered about that though.
I once sprayed my brake discs with penetrating oil mistaking the can for brake cleaner but I spotted it straight away. Both cans are the same green colour from toolstation.
Only use brake cleaner on your brake discs.
Doovy
PostPosted: 08:22 - 15 Jul 2010    Post subject: Reply with quote
Rapdude wrote:
My discs have a film on them, a combo of the sprays i have .. Laughing Brakes still work .. kind of ... Rolling Eyes Very Happy
its a 125, you dont need brakes Laughing
DrDonnyBrago
PostPosted: 08:35 - 15 Jul 2010    Post subject: Reply with quote
WD on the brakes is a big no no - got some on my rear brake and it reduced it to nothingness - change of pads were due anyway so wasn't an issue for long but I wouldn't fancy the same thing up front.
Cans of spray brake cleaner should sort it out, I've also heard of people baking their pads in the oven to burn oil/grease off.
PostPosted: 12:27 - 15 Jul 2010    Post subject: Reply with quote
Brake pads are absorbent, and they will absorb any grease or oil or lubricant which is sprayed onto the disc. It will not 'burn off' of the pads and it will reduce your braking ability.
In short, don't do it, if you do it on purpose you're a moron.
DrDonnyBrago
PostPosted: 12:57 - 15 Jul 2010    Post subject: Reply with quote
Rapdude wrote:
PS .. ANY brake disc cleaner recomendations .. ?? Thumbs Up Karma
Anything that says brake cleaner on the front will be fine - just go for the cheapest one.
PostPosted: 14:54 - 15 Jul 2010    Post subject: Reply with quote
Rapdude wrote:
Yes .. i'm a moron, but your the only busa rider that wears a hi vis and has purposedly derestricted the bike .. Middle Finger Laughing
Whoandwhatnow? I think the UK military ought to deploy you to confuse the enemy.
"He said wha...." *boom*. Lambs to the slaughter.
nowhere.elysium
The Pork Lord
PostPosted: 15:04 - 15 Jul 2010    Post subject: Reply with quote
Rapdude wrote:
Well if you have no ammo, make it up .. Laughing
It's like poker Mar, if i got crap hands, i'll just have to pretend i've got good hands .. Rolling Eyes
You could at least try to make sense, though. You seem to have a gift for non sequiturs that is, frankly, stunning. Your description of your old micra was a brilliant example:
Person 1: "Oh yeah - was it the 16-valve one, or one of the old 8-valves?"
Rapdude: "One wing mirror!"
Everyone Else At The Time: "Wut?"
Taking the piss is a grand thing, but it fails horrifically if no-one else gets it.
Bendy
Mrs Sensible
PostPosted: 16:54 - 15 Jul 2010    Post subject: Reply with quote
You should spray more on them.
Bendy
Mrs Sensible
PostPosted: 16:59 - 15 Jul 2010    Post subject: Reply with quote
Rapdude wrote:
Your such a drama queen ... Rolling Eyes Wink
I prefer 'sarky, miserable, Hitler bitch' but whatever.
mattgirv
PostPosted: 17:17 - 15 Jul 2010    Post subject: Reply with quote
Yeah, in answer to your original question both ACF50/WD40 are lubricants. WD40 is a fairly crap one, but the gist is don't put any sort of lubricant anywhere near your brakes and if you do wash it off.
The pads also tend to absorb the moisture as well so it can be quite problematic if you actually try to use your brakes after getting lubricant on the discs.
Bikes: 1998 Honda VFR800Fi, 26,500 miles Laughing
1989 Honda CB-1, 38,000 miles
PostPosted: 17:18 - 15 Jul 2010    Post subject: Reply with quote
Yes, but in poker you're doing the equivalent of shouting "SNAP!".
The last post was made 16 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 136.06 Kb
