To fit crash bungs or not...
Stephen
PostPosted: 20:03 - 16 Jul 2010    Post subject: To fit crash bungs or not... Reply with quote
Got a cbr400rr all standard or very easy to return to standard.
Need to drill 220mm holes in fairings to fit crash bungs?
Is it worth fitting them for the accidental dropping etc even though it meansd drillinh holes into fairings, and would this have a negative effect on value or for potential buyers in the future?
Also what are general opinions on crash bungs?I've been looking at the R&G ones as they seem the best on looking.
Thanks,
Stephen
Sorry for any poor spelling etc just starting to lose my rag tried posting few times but blackberry being stupid.
Stephen
The Proudest CG Owner
Clanger
Stirrer
PostPosted: 20:06 - 16 Jul 2010    Post subject: Reply with quote
YES.
WetSparks
PostPosted: 22:13 - 16 Jul 2010    Post subject: Re: To fit crash bungs or not... Reply with quote
I'm assuming you mean 2 * 20mm holes. 220mm ain't half big Surprised
And +1 for yes.
angryjonny
PostPosted: 00:20 - 17 Jul 2010    Post subject: Reply with quote
I have R&G bungs on my FZ1. I'd almost go as far as describing them as "tolerable".
m0l0t0v
PostPosted: 00:40 - 17 Jul 2010    Post subject: Reply with quote
I'd say yes.
The crash bungs will protect the fairings far far better even sjut by dropping it on it's side at 0mph.
They do have bad side effects, but the good points outweigh the bad points I'd say. Unfortunately on my Hornet the crash bung is what caused the big fuck up in the engine Sad
But I'd still have crash bungs, and will do once it's rebuilt Thumbs Up
It shouldn't affect the price as most bikers tend to buy crash bungs I find.
0ddball
PostPosted: 11:33 - 17 Jul 2010    Post subject: Reply with quote
I'd go against the grain and say no, unless they are already a bit rough. Your damaging the fairings to stop them getting damaged.
Even more important if its an older bike with mint fairings as they can be almost impossible to find as i've found with my zxr. Pretty much every panel i've come across on ebay has some damage and i'd pay real good money for a set of perfect unmolested ones.
Slacker24seve...
PostPosted: 16:41 - 17 Jul 2010    Post subject: Reply with quote
Emphatically YES!
They saved me and my Hornet hundreds in a low speed tumble. I braked too hard on some gravel and the front washed out... game over. Instead of crunching everything I ended up with a broken rear indicator, a few scuff to the speedo casing (replacement £10 on ebay) and a scrape on the tail fairing.
The bars got slightly bent (and I needed an excuse for some Renthals anyway) but I have no doubt that without the bungs they would have just folded into the tank. The engine casings would have taken all of the rest of the impact and I expect I'd need a new gear lever/linkage and clutch lever too.
Regards
Marcus
Banger rallies are ace
m0l0t0v
PostPosted: 16:53 - 17 Jul 2010    Post subject: Reply with quote
While I can see where you're coming from I'd rather have a small hole drilled into perfect fairings and come off with only some tiny scuffs, rather than not having drilled a small hole then coming off and having them completely ruined. Thumbs Down
But I do see where you're coming from. Thumbs Up
The last post was made 16 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 59.18 Kb
