| Wahlberg |
 Wahlberg Two Stroke Sniffer
 Posted: 12:40 - 18 May 2010 Post subject: zx6r F3 Brake Judder |
My zx6r has developed a bit of judder on the front brake, I cleaned the discs and the juddering stopped for about 25 miles or so but then came back.
I've been riding it still because it's not that bad but don't want to carry on if it's going to break it.
I'm pretty sure I've got a warped disc, but it did stop for a while when it was cleaned so does anyone know what else could it be? ____________________ If you can't fix it with Gaffa tape, you havn't used enough Gaffa tape!  |
| Phoenix |
 Phoenix Twisted Firestarter
| AJ |
 AJ Nitrous Nuisance
 Posted: 16:08 - 18 May 2010 Post subject: |
check your head stock bearings as well see if their is any play in them as this will give a judder when breaking. If there is tighten them a little if that dont work then you will have to replace them.
Not been wheeling av you  |
| Wahlberg |
 Posted: 07:02 - 19 May 2010 Post subject: |
Not intentionally! I'll whack it in a stand later and have a look. I only seemed to get it at about 25-40mph ____________________ If you can't fix it with Gaffa tape, you havn't used enough Gaffa tape!  |
| Maruchino |
 Maruchino Spanner Monkey
| Phoenix |
| Wahlberg |
 Posted: 22:21 - 11 Jul 2010 Post subject: |
I've only just got around to posting back on here again! Cheers for the words of wisdom
I put it on the paddock stand and it's the offside disc thats wobbling, I think it's from where I tried to ride off with the disc lock on - DOH! Didn't drop it though luckily
Anyway I think it needs replacing, does anyone know if I need to get both sides replaced or if I could just change the one? The one I want to keep has done 14k. I only ask because they're bloody expensive! ____________________ If you can't fix it with Gaffa tape, you havn't used enough Gaffa tape!  |
| jam125 |
 jam125 Borekit Bruiser
| Wahlberg |
 Posted: 19:25 - 16 Jul 2010 Post subject: |
Nice one dude, is it 2 wavey discs or one? If it is 2 I definately be interested! I've got the standard ones on there atm. It'd be a bad idea to mix them I think ____________________ If you can't fix it with Gaffa tape, you havn't used enough Gaffa tape!  |
| Vincent |
 Vincent Banned
| jam125 |
| Noxious89123 |
 Noxious89123 World Chat Champion
| Vincent |
 Vincent Banned
| Wahlberg |
 Posted: 19:36 - 22 Jul 2010 Post subject: |
It's going to be either a new original or 2 new wavey ones then, cheers guys, do you know a good place to get hold of them that doesn't charge the earth? ____________________ If you can't fix it with Gaffa tape, you havn't used enough Gaffa tape!  |
The last post was made 15 years, 168 days ago. Instead of replying here, would creating a new thread be more useful? |
