strange rear wheel problem?
gray84
PostPosted: 21:11 - 17 Jul 2010    Post subject: strange rear wheel problem? Reply with quote
right im back off out into the garage in a sec.
i took my rear wheel off 2 days ago to get my new tyre to fit.
just picked the wheel up and gone to fit it.(easiest job in the world)
got the wheel on and all in line(adjuster bolts didnt even more)
the caliper bracket it touching the disc. ive sat and looked and removed and tried again and there is nothing i can do!!! there is no room for any spacers and ive put the 1 spacer back on that come off in the 1st place.
what am i missing? i feel a right prat. its like the disc is a few mm thicker than it was before..
bike is a 2008 r1
DONT LAUGH
That_Hornet
PostPosted: 21:17 - 17 Jul 2010    Post subject: Reply with quote
Have you got the spacers in the right way round?
Casper
PostPosted: 21:39 - 17 Jul 2010    Post subject: Reply with quote
You make it sound as if the disk location is the only problem. If so it sound like to me you pressed the lever when the wheel was off. Prize the pads back with a bit of soft wood.
gray84
PostPosted: 21:53 - 17 Jul 2010    Post subject: Reply with quote
the wheel goes in place nice and the disc sits in the caliper.
BUT the caliper mount is touching the disc. ill try and get a picture
on the N/S you feed the spindle/bar through the whhel and it has the slide block on it. then on the O/S you have the wheel/caliper mount/swingarm/spacer/nut
That_Hornet
PostPosted: 22:02 - 17 Jul 2010    Post subject: Reply with quote
Not sure if this would help
Clicky
gray84
PostPosted: 22:07 - 17 Jul 2010    Post subject: Reply with quote
ok im missing a spacer.. must have been stuck to the wheel and lost during the tyre change.... gggrrrrrrrrrrrrr
gray84
PostPosted: 22:10 - 17 Jul 2010    Post subject: Reply with quote
Clicky
thank you.....
from looking at that. im not missing anything....
Casper
PostPosted: 22:22 - 17 Jul 2010    Post subject: Reply with quote
gray84 wrote:
Clicky
thank you.....
How about one of the spacers is fatter at one end than the other and you have it the wrong way round? or you got the N/S O/S spacers on the wrong side.
TUG
PostPosted: 22:38 - 17 Jul 2010    Post subject: Reply with quote
Its cos the cush drive has been disturbed, rubber mallet the sprocket till it wont go anymore into the rim, then refit, use a blade screw driver to lever it slightly if its still being a cunt.
Haz ER-5, innit!
gray84
PostPosted: 22:45 - 17 Jul 2010    Post subject: Reply with quote
really?
is all that bearing part suposed to move from one side to the other?
gray84
PostPosted: 22:46 - 17 Jul 2010    Post subject: Reply with quote
there is no room for spacers so this would make sense...im going to go have a wack
gray84
PostPosted: 23:12 - 17 Jul 2010    Post subject: Reply with quote
snigger... Laughing
lol....
on a serious note though. that thing isnt going anywhere...
gray84
PostPosted: 00:27 - 18 Jul 2010    Post subject: Reply with quote
just been reading the ownersclub and maybe the dust cover/spacers are on the wrong sides. the one on the sprocket side is bigger so if i was to swap them round the wheel would be moved away from the caliper mount by a few mm.
im guesing the tyre fitter removed them or they fell off maybe?
thanks for your info guys
gray84
PostPosted: 16:57 - 18 Jul 2010    Post subject: Reply with quote
yes...... spacers/dust covers on the wrong sides....
The last post was made 16 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.75 - MySQL Queries: 13 - Page Size: 80.86 Kb
