Honda Cg 1999 Choke
Louis101993
PostPosted: 10:42 - 19 Jul 2010    Post subject: Honda Cg 1999 Choke Reply with quote
Right, after alot of confusion and research i've found out that my Honda Cg's choke has 3 settings.
Fully up - Full choke
Half way - Half choke
Fully down - No choke
The bike seems to start every time without any choke, is this normal?
When idling it seems like the engine is running faster than it should be?
When i first start the bike up, with no choke, if i rev her abit to much, suddenly she misfire, is this also normal?
Sorry for the nooby questions, thanks in advance!
radical
PostPosted: 11:15 - 19 Jul 2010    Post subject: Reply with quote
Starting without choke is normal in the summer months , if you are revving your bike from a cold start them the odd misfire is normal. As with all fourstrokes its best to warm the bike up first before revving it too much, this would only take 2-3 minutes on a CG as they are air cooled. If you remove your sparkplug after a good run and check the colour of the plug this will give a good indication of how the engine is running, look for a light brown colour. The CG125 likes clean oil and I would recommend it is changed at 1500 mile intervals and always topped up as needed as they run a lot better on good clean oil.
Louis101993
PostPosted: 11:28 - 19 Jul 2010    Post subject: Reply with quote
I generally do let her warm up, i just hold a few thousand revs on to 30 seconds and then leave her idling for a minute or two, i'll check the plug colour later on, she's got her MOT to pass in 2 hours after replacement of a fork seal Very Happy
The last post was made 16 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 35.25 Kb
