Part 2 help
timboellis
PostPosted: 03:20 - 19 Jul 2010    Post subject: Part 2 help Reply with quote
Can some of you give me hints on what to do in preparation for part 2 test as still unable to get any lessons up here.
I have looked over the routes any feedback on what they are looking for?
I have been riding 125cc for over 12 years or so, so suspect need to get rid of a lot of bad habits
Minty
PostPosted: 17:09 - 19 Jul 2010    Post subject: Reply with quote
I did the old test, so can't offer much in the way of advice.
However, have you joined your regional forum and asked the question there? Could well be there is a person willing to come and show you a few pointers?
Best of luck!
My fingers smell of your mum.
angryjonny
PostPosted: 17:50 - 19 Jul 2010    Post subject: Re: Part 2 help Reply with quote
I did the old one, but I think the new one is more or less the same but without the manoeuvres. My test wasn't local to either me or where I did my training, so the best prep I did was to go to the test centre with my instructor and chat with a local instructor there who had a student out on his test at the time. He could tell us where the test routes went, where there were awkward junctions and other stuff that has caught students out in the past. Then I went and practiced those bits. Then did the test: zero minors Thumbs Up
Curtmeister
PostPosted: 01:09 - 26 Jul 2010    Post subject: Reply with quote
Observations and Lifesavers are key, miss them and you will pick up minors quick. Also let the examiner know that you are looking in your mirrors regularly and stick to the speed limit. Other than that don't do anything silly and don't worry if you go the wrong way as it doesn't matter.
Best of luck with it when you go for it Smile
Bikes: 54 Reg Gilera DNA50 > V Reg Kawasaki BN125 Eliminator > P Reg Suzuki Bandit N600 > 57 Reg Suzuki Bandit 650
Cages: 58 Reg Vauxhall Corsa 1.25 CDTI
PostPosted: 12:13 - 26 Jul 2010    Post subject: Reply with quote
ok, i done my mod 2 a month ago and passed.... eventually!... so its still reasonably fresh in my mind (considering i had to do it 3 times to pass its not surprising)
as with mod 1 the lifesavers and shoulder checks are important, you will fail for missing them. when stopped get into first. you will get a minor for gear selection if your in the wrong gear. keep the left foot on the floor, right foot on the back brake. pulling away do a check over each shoulder and move away. trying to keep to the middle of the lane
you will be expected to ride past parked cars, right lifesaver check before moving out of the centre of the lane your in. and left lifesaver before pulling back in.
you will do a couple of starting from stand still. the instructor will ask you to pull in when its convenient. use your common sense. your not going to pull in at a junction. or at a bus stop. before pulling away have a good look. theres nothing wrong with you taking your hand off the throttle and putting it behind you on the seat to make sure you can see.
angled start is just pulling out behind a parked car. when the examiner tells you to pull in behind the parked car dont pull right in to the kerbside. pull in about half of the car distance. ideally you want to be lining up with the boot handle. make sure you leave yourself plenty of room to pull out again tho. and once again look.
hill starts. keep your foot on the back brake to prevent rolling back (instant fail if you do). once again have a good look behind you down the road, i failed once because i looked and didnt see so make sure you have a good look, keep the revs busy and pull away gently.
road positioning and reading the roads are important. checks before pulling away, shoulder checks at roundabouts.
when turning left at a junction pull up as close to the kerb as possible. for right hand turns as close to the centre line as you can. if the examiner can get his bike inside you the chances are he will and you will fail.
but the most important thing to do is ride for yourself and try and relax. its easier said than done but try and forget you have this man scrutinizing you and instead he's just telling you where to go.
take your time. its better to get a fault for undue hesitation than it is to get a fail for pulling out when you should have waited.
sorry its long winded but hope it helps
RussBLS
PostPosted: 14:24 - 26 Jul 2010    Post subject: Reply with quote
Just over do it with observations. Such as every time you move road position.
nathandenniso...
PostPosted: 16:04 - 26 Jul 2010    Post subject: Reply with quote
rob yarrr wrote:
just keep on check with lifesavers,speed limits and road positioning
there the main things really,i failed on something stupid really,lack of concentation from doing a wrong turning and worrying
just ride nice and steady but keep to the speed limit,i got a major for dong about 50ish on a nsl road
good luck Smile
but aren't NSL's 60?
C-Pk
PostPosted: 16:18 - 26 Jul 2010    Post subject: Reply with quote
Yes but your limited to 45 on L plates
Passed Mod 2 - 6th August 2010
First and Current Bike - 2008 Suzuki SV650SK8
Curtmeister
PostPosted: 16:25 - 26 Jul 2010    Post subject: Reply with quote
Really :S I did 60 and didn't get any minors or majors :/
C-Pk
PostPosted: 16:35 - 26 Jul 2010    Post subject: Reply with quote
how
Curtmeister
PostPosted: 16:45 - 26 Jul 2010    Post subject: Reply with quote
The examiner was from a different test centre and was filling in for another examiner. He may not have picked up on the national sign.
C-Pk
PostPosted: 17:01 - 26 Jul 2010    Post subject: Reply with quote
Doesn't matter. Your a Learner. He should know you can't go above 45.
CptBlack
PostPosted: 17:04 - 26 Jul 2010    Post subject: Reply with quote
Are you talking about in NI or the rest of the UK?
nathandenniso...
PostPosted: 17:39 - 26 Jul 2010    Post subject: Reply with quote
Agreed, I have passed many police man at 60mph in a 60mph zone and never said anything
Benson_JV
PostPosted: 17:57 - 26 Jul 2010    Post subject: Reply with quote
No... Laughing
Curtmeister
PostPosted: 18:40 - 26 Jul 2010    Post subject: Reply with quote
rob yarrr wrote:
piss off NI people confusing the forum.
yes a nsl is 60,he was just looking for something to fail me on tbh
Thats sound then, thanks for clearing that up dude Smile
C-Pk This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
ian789
PostPosted: 22:17 - 26 Jul 2010    Post subject: Reply with quote
C-Pk wrote:
ROB YARR you prick, I apologise if the rules are slightly different over here.
No need to be a Jack ass about it.
Pathetic loser. Learn some respect.
Learn some common sense! Look on the OP's profile and he's not from NI Rolling Eyes
So it's best you get on your bike and ride off, being careful not to exceed 45mph of course Laughing
Curtmeister
PostPosted: 22:25 - 26 Jul 2010    Post subject: Reply with quote
So is nsl 60 over here and 45 on l plates in NI?
C-Pk
PostPosted: 22:28 - 26 Jul 2010    Post subject: Reply with quote
Yes, seems that way. But some people need to grow up and learn to speak properly to people when they make a small mistake.
Apologise if I made it confusing for you. I was unaware that the law was so different between our countries. It is all the UK after all.
The last post was made 16 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 122.62 Kb
