1992 gsxr 400 - overcharged?
bmwsport
PostPosted: 08:47 - 21 Jul 2010    Post subject: 1992 gsxr 400 - overcharged? Reply with quote
Hi guys,
i'm looking at a gsxr 400 that has a battery overcharging fault, is this common on these bikes or is there items which are most likely to cause this? my concern is that it may have wiped out all the electrics on the bike/damaged wiring etc. is this possible?
Cheers!
MaybeGuy
PostPosted: 09:05 - 21 Jul 2010    Post subject: Reply with quote
if it works it hasnt fried anything. Thats what fuses are for.
And reg/rect at fault
bmwsport
PostPosted: 09:11 - 21 Jul 2010    Post subject: Reply with quote
ok bud cheers, i'm trying to find out exactly what does/doesnt work, but he says the bike won't start because of this however the engine is sound.. fairly hard to prove i guess lol, if the rectifier goes i presume on turning the ignition on everything should light up as normal clocks wise? or does it just knock everything out completely?
PostPosted: 09:22 - 21 Jul 2010    Post subject: Reply with quote
If you get another battery, it should be ok to plug in to check the engine sounds ok at least.
As matt says, reg/rec will need to be replaced at some point most probably, but rest should be ok.
MaybeGuy
PostPosted: 09:29 - 21 Jul 2010    Post subject: Reply with quote
if the reg rect goes everything should still work. It should even run too.
If it doesnt, its probably the generator which would be a lot more hassle and cost, and could give the same symptoms.
Plus, if it doesnt run... How does he know its overcharging?
Avoid i reckon. Sounds like a dodgey geezer
Phoenix
Twisted Firestarter
PostPosted: 12:47 - 21 Jul 2010    Post subject: Reply with quote
If the regulator is fried it'll often burn or slightly melt the plug that goes into it but it's the first thing to swap because even if the alternator is at fault it's probably killed the regulator too, but you need to check each bit.
The last post was made 16 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 47.86 Kb
