Hot Hoseing ..
Paulington
PostPosted: 13:50 - 21 Jul 2010    Post subject: Reply with quote
Cold rinse.
Detergent wash.
Cold rinse.
Dry with a chamois.
Wax on with a microfibre.
Wax off with a microfibre.
Thumbs Up.
SamJL
PostPosted: 13:51 - 21 Jul 2010    Post subject: Reply with quote
I just use cold water, apparently in the winter you shouldn't use warm water at all due to it having a reaction with salt, and speeding up corrosion.
2009 CBR1000RR
2004 KTM 200SX
2004 KTM 65SX Very Happy
TUG
PostPosted: 21:52 - 21 Jul 2010    Post subject: Reply with quote
This is correct.
Haz ER-5, innit!
stuartadair
PostPosted: 22:29 - 21 Jul 2010    Post subject: Reply with quote
Nobody told me you had to clean your bike - When did that rule start Wink
Frost
PostPosted: 00:03 - 22 Jul 2010    Post subject: Reply with quote
Warm water is more reactive, so will help shift dirt quicker. It will also help liquify grease and oil and evaporate quicker. Obviously the higher temperature might help remove grease that you actually want to keep such as chain lube. A hot pressure wash every now and then helps get rid of the worst shit, but provided you wash it regularly you will be fine with cold water.
c_dug
PostPosted: 00:37 - 22 Jul 2010    Post subject: Reply with quote
Hot water keeps the hands warm Thumbs Up Doesn't make much difference in the summer but screw using cold water when its 2 degrees outside in the middle of January!
c_dug
The last post was made 16 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 65.54 Kb
